Viton valve seals?
Old Mar 8, 2007 | 08:18 AM
92DAturboteg's Avatar
Default Viton valve seals?
I've been searching fo a while and can't seem to get a deff answer on this. When I had my head assembled my builder reccomended Fel pro viton valve seals I had him put them in. Recently I've had a buddy tell me that the same builder used them in his head and the exhausts leaked badly. I need to know if anyone else has had any experience with these seals before I change them.
Modified by 92DAturboteg at 9:39 AM 3/8/2007
Old Mar 8, 2007 | 08:36 AM
jdmturbosol's Avatar
Default Re: Viton valve seals? (92DAturboteg)
the only difference in the material is that it is a little harder and much more resistant to heat
I think oem itr seals are viton
usually you can tell if its viton if its RED rubber
Old Mar 8, 2007 | 08:41 AM
Default Re: Viton valve seals? (jdmturbosol)
I understand that viton is much more resistant to heat. I need to know if anyone else has had a problem with them leaking?
Old Mar 8, 2007 | 09:56 AM
Bump
Old Mar 8, 2007 | 12:42 PM
98_Coupe's Avatar
What the fork do valve-stem seals have to do with exhaust leaks?
Old Mar 8, 2007 | 12:55 PM
Default Re: Viton valve seals? (Russell_K)
The exhast valve seal leaking oil into the port, this has nothing to do with ehaust.
Old Mar 8, 2007 | 06:55 PM
NJIN BUILDR's Avatar
I've had good luck with aftermarket seals as long as they are steel shelled like the stockers.Every problem I have had with aftermarket seals, they were the all rubber (or all viton) ones with wire bands around the guide area.They often pop off the guides.
Old Jun 15, 2007 | 07:26 AM
RC000E's Avatar
Default Re: Viton valve seals? (NJIN BUILDR)
yeah.....I'd have to say that they leak because this set of blue viton seals I just got don't come with the two different sized seals for intake and exhaust....they use one "universal" size.
Intake valves are about .001 in diameter different from exhausts, which is why you have the white spring and black spring seals. Helms states clearly not to mix them. That's why those damn things leak...I guarantee it. Now here I am with a set of these f*ckers and this ****'s gonna leak watch.
Old Jun 15, 2007 | 08:26 AM
raene's Avatar
I just did a set of fel-pro seals on my B18A engine, they were completely blown before and leaking quite badly. The new ones looked just like the old ones - metal base with a rubberized coating on the inside and a shaped cap with the spring ring. Looked identical to OEM, and seem to work all right as well. I don't know if they're leaking a little bit or not, my only gauge is that it's no longer puffing big clouds of smoke I can't comment on their resistance to high power or how their VTEC seals are, when I rebuilt the VTEC head I used OEM seals. Hope that helps somewhat though
Old Jun 15, 2007 | 12:01 PM
RedEj8's Avatar
Default Re: Viton valve seals? (raene)
It also depends on how good of shape your valve guides are in. Worn out guides will leak oil like a ****...ask me how i know
Old Jun 15, 2007 | 12:13 PM
ninesecrx's Avatar
Default Re: Viton valve seals? (RedEj8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedEj8 &raquo;</TD></TR><TR><TD CLASS="quote">It also depends on how good of shape your valve guides are in. Worn out guides will leak oil like a ****...ask me how i know</TD></TR></TABLE>
And play in the valve means it hurts the seal.
On the intakes, we usually run a Polyacrylic seal and Viton on the exhaust.
HellaFab
Jun 28, 2011 07:37 AM
Maddvtec
Dec 17, 2010 08:53 AM
SYN4DRDX
Jul 9, 2005 12:09 PM
1.8EG-T
Dec 14, 2003 02:56 PM
se93
Nov 22, 2003 07:02 PM
