d15b7 at 9000rpm
Old Mar 6, 2007 | 06:57 PM
hold your breath's Avatar
Default d15b7 at 9000rpm
what do I need done to the head to rev out that high, safely.
I shift at 9k most of the time, but now I want to build the head?
Help please.
Old Mar 6, 2007 | 07:00 PM
slowsol95's Avatar
Default Re: d15b7 at 9000rpm (hold your breath)
man prepare yourself, let the flaming begin.
Old Mar 6, 2007 | 07:48 PM
slodel's Avatar
shift now at 9000?? holy cows
must have a bad *** bottom end?
tell us your setup, I also would like to rev to 9000
must be expensive to make power that high
Old Mar 6, 2007 | 08:42 PM
blackdelslo's Avatar
Default Re: d15b7 at 9000rpm (slodel)
You could start with balancing and blueprinting, aftermarket springs and retainers.
Then having a custom cam made for you that will actually make power at 9000 and tune it. This project would be unpractical as hell.
Build a DOHC to do that with.
Old Mar 6, 2007 | 08:47 PM
nateg's Avatar
harry....i need nos, two of these by tonite
Old Mar 6, 2007 | 08:50 PM
Schister66's Avatar
Man U FTW
there's no benefit to revving out higher if your car doesn't make any more power up top.....i dont see the point unless you're making good power
Old Mar 6, 2007 | 09:04 PM
slodel's Avatar
Default Re: d15b7 at 9000rpm (nateg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nateg &raquo;</TD></TR><TR><TD CLASS="quote">harry....i need nos, two of these by tonite</TD></TR></TABLE>
boy i cant imagine you have a problem with srt4s
haha
Old Mar 6, 2007 | 09:49 PM
idahos_dirty_d's Avatar
man ur give that d15 a beating. that thing is losing alot of power at that high. there really is no reasing to be spinning that thing like that. im not trying to flam ya or anything but im supprised it has lasted. i have a d15 running 7psi and it hates life abover 6500 7000 and i take it to 7000 and i can just feel the power band drop. but if u want to just search online and see what u can find. ull have to find a cam that is huge engough to make it worth it. but there hard to come by for a d15. take if from another d owner and what that other guy said, if u want to spin that high and it do somthing go dohc.
Old Mar 7, 2007 | 08:41 AM
I know I dont make any power after 6800rpms.
But reving out to 8k-9k help alot when racing against mustang gt and the mach 1.
The funny part is I'am on a stock block and stock head. So Ima do a little work on the head to reduce the friction.
Im pretty much want to blow it up.
My setup is
d15b7 non-vtec
ss auto chrome kit
spoolin performance log manifold
blox fmu
ignition wires
fidanza 7lbs flywheel
act clutch
8psi.
Old Mar 7, 2007 | 10:38 AM
stockb18c's Avatar
^ wow thats all im saying on that one
Old Mar 7, 2007 | 11:11 AM
JoePSI's Avatar
Default Re: (stockb18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hold your breath &raquo;</TD></TR><TR><TD CLASS="quote">I know I dont make any power after 6800rpms.
My setup is
d15b7 non-vtec
ss auto chrome kit
blox fmu
ignition wires
act clutch
8psi.
You should try changing your head to a vtec head and getting rods/pistons & machine work. then run more boost. It would be alot more beneficial than building the engine to rev out to 9k.
Old Mar 7, 2007 | 11:23 AM
mr.speaker's Avatar
Default Re: (JoePSI)
He is full of ****.you can't rev the stock internal d15b7 to 9000revs,even with no rev limit it will stop at around 7800 and blow at 8000...So I don't know what the hell he's talking about.
By the way i know this because i missshifted and from 3rd to 2nd along time ago and it blew at exactly 8075 rpm via memory tach.
Old Mar 7, 2007 | 01:23 PM
HiProfile's Avatar
Default Re: (honda89crxsi)
I got my pristeen, RUST-FREE (live in rust-belt WI), black 95 EX for very cheap because the previous owner's BF thougth the z6 could take 9000 rpm - and tossed a rod out the block. And that was NA
My guess is you just have a turbo thats about 2x as big as it should be. Get a properly-sized turbo and you won't have to wait till stock redline to see full-boost, let alone have to take it to 9k to beat moostangs. ****, there's guys with 50trim T3's on non-vtec SOHC's raping GT's...albeit 17+ psi
Old Mar 7, 2007 | 01:25 PM
Schister66's Avatar
Man U FTW
Default Re: (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">I got my pristeen, RUST-FREE (live in rust-belt WI), black 95 EX for very cheap because the previous owner's BF thougth the z6 could take 9000 rpm - and tossed a rod out the block. And that was NA
My guess is you just have a turbo thats about 2x as big as it should be. Get a properly-sized turbo and you won't have to wait till stock redline to see full-boost, let alone have to take it to 9k to beat moostangs. ****, there's guys with 50trim T3's on non-vtec SOHC's raping GT's...albeit 17+ psi </TD></TR></TABLE>
agree with everything...also if you ditch that piece of **** FMU you're using, you'll gain some power w/ a real tune
Old Mar 7, 2007 | 02:36 PM
Na, Im not full of ****. Its called a chipped ECU bra.
And I do not shift at 9k all the time. I regularly shift at 7k-8k.
I use 9k just for extra rpm.
My car is just my toy. Lol
Old Mar 7, 2007 | 02:45 PM
EJ1 wilcox's Avatar
Default Re: (hold your breath)
You are a retard.
Nice work getting people to believe that you are serious though.
Attention ******
Old Mar 7, 2007 | 02:48 PM
g23_ej1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hold your breath &raquo;</TD></TR><TR><TD CLASS="quote">Na, Im not full of ****. Its called a chipped ECU bra.
My car is just my toy. Lol</TD></TR></TABLE>
look bra.. you just contradicted yourself... "i know i dont make power past 6800, but i need it to beat mustangs blah blah" sorry bra, but i dont believe you.. my z6 has 265whp and i shift at 8k and im pushin it.. 9k on a motor that only wants to see 6500ish .. blah..
Old Mar 7, 2007 | 02:57 PM
Schister66's Avatar
Man U FTW
stop saying bra.....are you like 17 and dress in South Pole ****?
This thread is annoying and you're retarded
Old Mar 7, 2007 | 03:10 PM
BoostedEG6's Avatar
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">stop saying bra.....are you like 17 and dress in South Pole ****?</TD></TR></TABLE>
people that dress like say bro..... hawaiians say bra if you have never been to hawaii than you dont know what I am talking about.... but if you have then you know what I am talkin about
ho bra that car be mean
Old Mar 7, 2007 | 03:11 PM
8herout's Avatar
This thread is annoying and you're retarded</TD></TR></TABLE>
DUDE, it ok they calling each other bra it not like they're call each other underwear or somthin
Old Mar 7, 2007 | 03:44 PM
mr.speaker's Avatar
Default Re: (8herout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hold your breath &raquo;</TD></TR><TR><TD CLASS="quote">what do I need done to the head to rev out that high, safely.
Help please.</TD></TR></TABLE>
you are full of ****..Do you even have a car BRA?
Old Mar 7, 2007 | 03:55 PM
BoostedEG6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda89crxsi &raquo;</TD></TR><TR><TD CLASS="quote">you are full of ****..Do you even have a car BRA?</TD></TR></TABLE>
you just kinda made your self look like an idiot
he never said he shifts at 9K all the time
most of the time does not mean ALL the time
Old Mar 7, 2007 | 04:17 PM
Newt Dog's Avatar
Default Re: (BoostedEG6)
9k + stock internals = kaboom!
Old Mar 7, 2007 | 05:22 PM
Schister66's Avatar
Man U FTW
Default Re: (Newt Dog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newt Dog &raquo;</TD></TR><TR><TD CLASS="quote">9k + stock internals = kaboom! </TD></TR></TABLE>
i think what you meant to say was
9k + stock internals = weak
10k or bust....
Old Mar 7, 2007 | 06:57 PM
HiProfile's Avatar
10k or bust....</TD></TR></TABLE>
Add in that thread about smaller motors being faster...10k pwnz teh vip3r! Bra!
