stock internals...what hp/psi to stop at for tune?
ok ive read through 280 pages on h23 turbos. but nothing that will answer my particular question. i dont know if i should be looking at hp or psi.
so im going to be running my stock internal h23 for maybe 6 months. i have a drag 4 kit, rc 750's, hondata s300, walbro 255 and all 3" exhuast parts. now when i get it tuned should i be looking more to stop at a certain hp area or stop at a certain psi. like if i hit say 265hp(just an example) on 7 psi should i back it down to hit less hp? if you need more info please let me know. thanks
Re: stock internals...what hp/psi to stop at for tune? (slodel)
sorry let me put it this way. on stock internals should i stop at 7 psi or stop around 240hp. im wondering which one i should be more worried about hp or psi on the stock block
Re: stock internals...what hp/psi to stop at for tune? (nonvteclude)
I think I kinda get your question.
You stop at a desired horsepower rating because remember a disco potato is going to produce less CFM at 5 PSI then a T66 is. So using PSI render yourself a "safe" zone is totally useless at that point there.
IF you add an exhaust 3in exhaust on the same set up that ran 7psi with a 2in one you'll make more power even without upping the boost.
so yes use horsepower if your worried about blowing your internals because of too much boost.
Re: stock internals...what hp/psi to stop at for tune? (DCxMagus)
ok thank you thats what i wanted to know, sorry for the confusion im still a little new to this so didnt know how to explain it very well
Its going to come down to what your tuner feels safe tuning it to, because in the long run, he is the one that holds your motors life in his hand.
Ask him, that will also tell a lot about a tuner depending on what he says.
Re: stock internals...what hp/psi to stop at for tune? (Hondatec38)
You can make a ton of power on stock motors, but the quesiton is how long will it last. Stock ringlandings are not supposed to handle that much power. While i am sure since Jeff did the tune its flawless, but hp breaks things on stock internals, plain and simple.
Still pretty badass to make that much power, and when people ask you can honestly tell them its stock from the headgasket to the oil pan
Re: stock internals...what hp/psi to stop at for tune? (urbansi)
thanks i will talk to him when it comes time to tune. im definately not trying to break any records with a stock block. just need it to run for 6-8 months. but thank you again
