turbo experts help please
Old Mar 7, 2007 | 04:29 PM
jamescb77's Avatar
Default turbo experts help please
So i found a turbo for a good deal and im wondering if it's to big for a honda app. its a MP 60-1 .70 .92 ar ill be running a built ls turbo motor stock cubes but all forged with cams and all the junk will this turbo work with fair effiecency.
Old Mar 7, 2007 | 05:09 PM
Schister66's Avatar
Man U FTW
what are your power goals and what is the use of this car (strip/street/autoX)??
Old Mar 7, 2007 | 06:28 PM
jamescb77's Avatar
my goals are going to be about 400 or so daily with maybe 500 or so for the track it will be my daily at first with weekends at the track until i can pick up another car to drive and then it will be weekends only
Old Mar 7, 2007 | 08:35 PM
Schister66's Avatar
Man U FTW
what engine?? What does the rest of the setup look like??
Old Mar 7, 2007 | 09:05 PM
jamescb77's Avatar
it will be a forged pistons and rods at 81mm bore ls motor with an ls head with cams intake etc basically a fairly built motor i don't really have any specs on the turbo setup as im going to get a turbo and build from there
Old Mar 8, 2007 | 06:46 AM
jamescb77's Avatar
so there is only one guy in here that is willing to help or knows anything about turbos some on guys someone give me a hand here
Old Mar 8, 2007 | 07:57 AM
DaveF's Avatar
Default Re: (jamescb77)
ill tell you the 1st thing you need to get rid of, and its that ls cyl head. swap a vtec head on it, leave the bottom end stock with the addition of aftermarket rods and pistons/head studs. spend the money wisely. its very simple to build a reliable setup anymore, that makes killer power.
Old Mar 8, 2007 | 11:02 AM
jamescb77's Avatar
i understand that the ls head doesn't breath as well as the vtec head but i didn't ask abotu a vtec head im not wanting to go vtec right now im wanting to stay ls and do a turbo my question is just do you guys think this is a suitable turbo for what im looking for or do you think it's to big thanks jamescb77
Old Mar 8, 2007 | 11:34 AM
DaveF's Avatar
exh housing seems rather large... is this a street car ? to take advantage of that you really need a higher reving engine or a larger engine, the LS is not either of those, especially in stock form
Old Mar 8, 2007 | 11:40 AM
jamescb77's Avatar
it's going to be a street car with a good amount of track duty and the motor is not really going to be stock if you read above i described it. im starting to think that maybe this is to big and just to go back to my hx35 that i had been looking at. let me know if you think that would be a better turbo
xfrankx
Aug 18, 2005 06:21 PM
6MTV6
Dec 22, 2004 06:47 AM
crazyex
Aug 15, 2004 04:44 PM
Mr.Saturn
Aug 3, 2003 08:16 AM
Jamison
11
Oct 30, 2002 11:22 AM
