Relative spool times for H22 on GT35R?
Old 03-07-2007, 09:51 AM
bb_one's Avatar
Default Relative spool times for H22 on GT35R?
I've been searching this up but have not found any conclusive information.
For those that are running a GT35R on an H22 setup, please chime in on the spool characteristics on this motor/turbo combination.
I am fully aware that your spool time is very dependent on your entire setup, but I am just looking for rough numbers.
Old 03-07-2007, 10:21 AM
KStuned's Avatar
Default Re: Relative spool times for H22 on GT35R? (bb_one)
We got 25 psi by about 5700... w/ .82 a/r, Topmount and 9:1. It is VERY dependent on the type of boost controller you are using. Make sure to keep the wastegate fully shut until the desired boost is reached, don't let it slowly bleed open.
Old 03-07-2007, 10:23 AM
Mykizism's Avatar
sup man, after nopi in march im switching my setup to a 35r .82 a/r when im done, you can hit me up and ill give you my numbers
Old 03-07-2007, 10:34 AM
bb_one's Avatar
Default Re: Relative spool times for H22 on GT35R? (Reid@KAIZENSPEED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid@KAIZENSPEED &raquo;</TD></TR><TR><TD CLASS="quote">We got 25 psi by about 5700... w/ .82 a/r, Topmount and 9:1. It is VERY dependent on the type of boost controller you are using. Make sure to keep the wastegate fully shut until the desired boost is reached, don't let it slowly bleed open.</TD></TR></TABLE>
Thank you, that was what I was looking for. At what RPM did the turbo start spooling?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mykizism &raquo;</TD></TR><TR><TD CLASS="quote">sup man, after nopi in march im switching my setup to a 35r .82 a/r when im done, you can hit me up and ill give you my numbers </TD></TR></TABLE>
Mike, sounds good bro, hit me up when you've made the switch.
Old 03-07-2007, 01:15 PM
h22 civic's Avatar
imo gt35r .82 perfect turbo for a h22 street/track car starts spool aout 3000 and full boost low 5000 makes good power you should see in the 500whp with a mild tune and built motor at around 20-psi
Old 03-07-2007, 01:57 PM
bb_one's Avatar
Default Re: Relative spool times for H22 on GT35R? (h22 civic)
Sounds good, that was what I was looking for, thank you
preludejones
11-27-2007 02:23 PM
ek9phantom
10-20-2007 09:08 PM
JDM BB4
03-26-2007 03:04 PM
8200RPM
06-14-2005 03:53 PM
Quick Reply: Relative spool times for H22 on GT35R?
