5 bar map sensor how do you its bad?
Old Mar 7, 2007 | 02:11 AM
94turboeg's Avatar
Default 5 bar map sensor how do you its bad?
I cant get a reading over 26psi on data log.How do i test it?Im using s300 hondata any help!
Old Mar 7, 2007 | 10:55 AM
94turboeg's Avatar
Default Re: 5 bar map sensor how do you its bad? (94turboeg)
anyone?
Old Mar 7, 2007 | 12:20 PM
White Smoke's Avatar
i my honda
Global Mod
Is this an AEM sensor? Whats the part #?
Old Mar 7, 2007 | 12:35 PM
94turboeg's Avatar
Default Re: 5 bar map sensor how do you its bad? (White Smoke)
yes dont know # right now
Old Mar 7, 2007 | 12:44 PM
i my honda
Global Mod
Get me the # and I will tell you if its a real 5 bar.
Old Mar 8, 2007 | 01:35 AM
94turboeg's Avatar
its a 5 bar ive boosted 36psi with no problem
Old Mar 8, 2007 | 04:27 AM
i my honda
Global Mod
If you have boosted 36psi then what is the problem??? Sounds like the sensor is fine to me. It just does not data log reading above 26? If thats the case then it seems to me that your hondata would be bad not the sensor...
Old Mar 8, 2007 | 04:31 AM
DaveF's Avatar
fwiw- we are boosting ~40 psi on a 3 bar. with no problems. haha this is going to change for this season though.
Old Mar 8, 2007 | 04:50 AM
vtekthis's Avatar
these sensors dont take vibration well, and they doo go bad, not often but can
use a cusion clamp if your sensor went dead next time
Old Mar 8, 2007 | 09:49 AM
94turboeg's Avatar
Default Re: 5 bar map sensor how do you its bad? (vtekthis)
sensor was on intake<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtekthis &raquo;</TD></TR><TR><TD CLASS="quote">these sensors dont take vibration well, and they doo go bad, not often but can
use a cusion clamp if your sensor went dead next time</TD></TR></TABLE>It was mounted in intake manifold<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke &raquo;</TD></TR><TR><TD CLASS="quote">If you have boosted 36psi then what is the problem??? Sounds like the sensor is fine to me. It just does not data log reading above 26? If thats the case then it seems to me that your hondata would be bad not the sensor...</TD></TR></TABLE>The higher boost # were when sensor was brand new .This motor isnt goning to see more than 30psi.So how do i test sensor?
stockb18c
Jan 28, 2009 03:28 AM
sihatch19
May 28, 2008 09:56 AM
1QwIkEf
May 20, 2008 06:07 AM
cigrafix
Sep 19, 2006 04:26 PM
vtekthis
Apr 10, 2005 06:00 AM
