Dyno vs. Track boost
Old Mar 6, 2007 | 03:08 PM
PT66Y922Rx83's Avatar
Default Dyno vs. Track boost
Those of you with high pressure turbo setups (30+psi), was there a big variation in steady held boost pressure on the dyno and real boost pressure seen on the track?
I was having some problems with boost creep on the dyno, so we changed the wastegate spring out for a much lighter one that got the boost down to where we wanted it. But on actual track runs, there is no creep and actual boost is much lower than the pressures reached on the dyno at the same settings.
Hopefully all that was understandable.
Chris
ImPuLsIvE
May 30, 2008 10:05 AM
2 0 3
Jan 22, 2008 07:42 AM
bigdgsr
Jul 7, 2006 09:09 AM
Drew Peacock
Sep 19, 2003 05:58 PM
Snafu-Si
Jul 12, 2003 10:12 AM
