Motor Build. which cams???
Old Mar 4, 2007 | 04:57 PM
rdeezy78's Avatar
Default Motor Build. which cams???
I am building an gsr block, b16a(jdm) head, with LS rods for a ls vtec powerband(torque wise). I will be running boost upwards to 20 psi. My question is would my b16 cams be good or should I go with gsr,ctr, or itr cams? I want to use stock cams. I will have forged block internals and will be replacing the springs and retainers with most likely supertech or equivalent for sake of argument. Assuming my valves and valve keepers are in good shape they will not be replaced. Thanks for any helpful input!
Old Mar 4, 2007 | 06:13 PM
spoolin turbo s's Avatar
Default Re: Motor Build. which cams??? (rdeezy78)
ctr or itr
Old Mar 4, 2007 | 06:14 PM
rocket256's Avatar
Default Re: Motor Build. which cams??? (spoolin turbo s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolin turbo s &raquo;</TD></TR><TR><TD CLASS="quote">ctr or itr</TD></TR></TABLE>
I got mine.
Old Mar 5, 2007 | 08:57 AM
White Smoke's Avatar
i my honda
Global Mod
From the sound of it GSR cams will work just fine for you. Save the extra flow and spend it on something else.
Old Mar 9, 2007 | 08:57 AM
rdeezy78's Avatar
Default Re: Motor Build. which cams??? (White Smoke)
But any of those over my b16 cams? Would my b16 cams be good though. I thought I read somewhere that the b16 cams, oh never mind it's the head flow of a b16 compare dto a itr. How about the b16 cams?
Old Mar 9, 2007 | 09:10 AM
BoostedEG6's Avatar
ok I have to ask this since it wasn’t said in the original post..... you are running the LS crank also right?
I would run ITR cams if I were you
Old Mar 9, 2007 | 11:18 AM
sp00led's Avatar
Default Re: Motor Build. which cams??? (BoostedEG6)
If you don't want to shell out the cash for ITR/CTR cams send me a PM as I have some GSR cams for sale.
Old Mar 9, 2007 | 02:28 PM
BlangBlangTEG-93''s Avatar
Default Re: Motor Build. which cams??? (sp00led)
CTR
Old Mar 9, 2007 | 03:34 PM
Teglove2's Avatar
Just got my mazworx cams!!!
Old Mar 12, 2007 | 09:36 AM
rdeezy78's Avatar
yes, I'm ruuning a ls crank with stock ls rods.
Old Mar 12, 2007 | 09:59 AM
flangemastermike's Avatar
sorry to thread jack but what engine code is the GSR, im from the uk and there called different things, im also in the same boat as you building b18c4 (170hp) and dnt know what cams to go for
Old Mar 12, 2007 | 12:46 PM
doood's Avatar
been there done that
Default Re: (flangemastermike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flangemastermike &raquo;</TD></TR><TR><TD CLASS="quote">sorry to thread jack but what engine code is the GSR, im from the uk and there called different things, im also in the same boat as you building b18c4 (170hp) and dnt know what cams to go for</TD></TR></TABLE>
b18c1 here in the states
Old Mar 12, 2007 | 03:13 PM
OceanStateTuning's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rdeezy78 &raquo;</TD></TR><TR><TD CLASS="quote">yes, I'm ruuning a ls crank with stock ls rods.</TD></TR></TABLE>
Have you ran it yet?
But alway to answer your question, GSR cams are better then B16, ITR/CTR is better then GSR and Mazworx cams if you are Ballin
Old Mar 12, 2007 | 03:29 PM
DaveF's Avatar
Default Re: Motor Build. which cams??? (OceanStateTuning)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OceanStateTuning &raquo;</TD></TR><TR><TD CLASS="quote">
But alway to answer your question, GSR cams are better then B16, ITR/CTR is better then GSR and Mazworx cams if you are Ballin</TD></TR></TABLE>
FWIW, mazworx cams are similar in price to brand new ctr/itr cams.
Old Mar 12, 2007 | 03:36 PM
Teglove2's Avatar
yeah i got mine slightly used but in great shape. They should go nicely with my gt4202....I've seen those things make power past 11k......scarey ****
Old Mar 12, 2007 | 03:38 PM
DaveF's Avatar
Default Re: (Teglove2)
haha you and me both !! (mazworx+4202)
HksHaitian
Nov 26, 2006 09:29 PM
RACEPAK
Mar 23, 2006 07:48 AM
JspecCivic94
Dec 12, 2005 08:50 PM
esp4life
Mar 8, 2005 12:25 PM
StinkyTofu
May 25, 2003 05:16 AM
