GSR not getting oil pressure
GSR not building oil pressure
Ok so today we went to fire my motor and we were getting nothing on the oil pressure gauge so we made sure the electrical connections were good, which they were...we pulled the valve cover and found not a drop of oil (yes there is oil in the engine)...The engine was just freshly built...I bought the oil pump in "brand new" condition off a member on here, I've already talked to him and he swears up and down that the pump is brand new from inlinefour and its never been used...Any ideas on what might be wrong?...I'm lost
Modified by boostedek9 at 8:31 PM 3/7/2007
Re: (boostedek9)
did you prime the oil pump? If not, then it'll take some time for the oil to get into the all the passages. That's what a good assembly lube is for. Usually I spin the motor with the starter only hooked up (ECU unplugged, spark plugs out) until oil pressure comes up.
we primed the car w/o the distributor or anything plugged in...and got nothing, as for the pickup and the gasket we're pulling the pan tomorrow to check that!
Re: (boostedek9)
try starting it for a few seconds see if it reads pressure... i did the same thing....prime the oil a few times..and no pressure in the gauge...but started it up, instant pressure...sometimes it takes a lil more then just priming..
Question, will the car build oil pressure and send oil to the head and what not by just priming it or does the car actually have to run for a few seconds for this to occur?
Re: (boostedek9)
if you properly lubed ur cams when u installed them, it will be ok for it to run for a moment...just close ur eyes and turn the key over! then open ur eyes and look at the gauge...BAM! pressure...haha just try it man..
Re: (y7turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by y7turbo »</TD></TR><TR><TD CLASS="quote">when i rebuilt my d16 it took about 45 seconds of cranking to even show on the gauge. after it started it shot up to 80psi.
good luck</TD></TR></TABLE>
Same here. Took quite a while, but then again D16's hold quite a lot of oil in their crank girdle. BTW I suggest pouring at least half a quart of oil directly onto the cams. Filling it all at the hole only gets a small section. They don't need much oil though, as the motor cranks at ~60rpm to start, and the cams move half crank speed. They're also billet steel and work-hardened, so there won't be a big issue with wear.
Re: (boostedek9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dark19Acura »</TD></TR><TR><TD CLASS="quote">Check your oil pan maybe is punched on the oil snifer!!</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedek9 »</TD></TR><TR><TD CLASS="quote">runs :D thanks fellas!</TD></TR></TABLE>
b20eghatch
11
07-12-2010 11:24 AM
lil'Joe1039
15
03-17-2007 12:05 PM
