slim fan question
Old Mar 8, 2007 | 11:56 AM
b18b1turbo's Avatar
Default slim fan question
got a question about slim fan.is pushing better or pulling better?
Old Mar 8, 2007 | 12:00 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: slim fan question (b18b1turbo)
unless the fan is made as a pusher, it is more effecient as a puller, although my fal fan i have on my fluidyne, i converted to a pusher, and had no issues. just make sure you reverse the polarity to have the fan spin the correct way. he hee.
Old Mar 8, 2007 | 12:14 PM
b18b1turbo's Avatar
Default Re: slim fan question (boostedcivicsir)
its made for pulling or pushing
Old Mar 8, 2007 | 12:21 PM
Mr. Badwrench
it was made for pulling, but it works ok as a pusher.
Old Mar 8, 2007 | 12:32 PM
jdmsiR20's Avatar
depends on the brand/style -- but if it flows enough cfm's in either direction you should be fine.
personally running a pusher style, at 1200 cfm, just to save space.
Old Mar 8, 2007 | 01:33 PM
katoeh2o's Avatar
pusher style is sopesed to be 80% as effeceint as a puller. So if you do a pusher just back sure it flow a little more.
I run a pusher fan and aluminum radiatior and it works well.
Old Mar 8, 2007 | 01:45 PM
EJ1 wilcox's Avatar
Default Re: (katoeh2o)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by katoeh2o &raquo;</TD></TR><TR><TD CLASS="quote">pusher style is sopesed to be 80% as effeceint as a puller. So if you do a pusher just back sure it flow a little more.
I run a pusher fan and aluminum radiatior and it works well.</TD></TR></TABLE>
Yup, I couldn't tell you why, but for some reason it's more efficient to run it as a puller if you can get away with it.
The only reason I would run it as a pusher would be if I needed the space. But my fan is so slim anyways it barely sticks out.
Old Mar 8, 2007 | 03:02 PM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18b1turbo &raquo;</TD></TR><TR><TD CLASS="quote">its made for pulling or pushing</TD></TR></TABLE>
But each fan is designed to work a better way ( pusher or puller ) , should say in the instructions. Ours do, I was pretty surprised to see it in the instructions.
Old Mar 8, 2007 | 03:53 PM
Mr. Badwrench
Default Re: (EJ1 wilcox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">
The only reason I would run it as a pusher would be if I needed the space. But my fan is so slim anyways it barely sticks out. </TD></TR></TABLE>
it is actually because when it is setup as a puller, the air goes through the rad first then the fan, when setup as a pusher, the air has a restriction because it has to go through the fan before being pushed through the radiator. hope that makes sense. he hee
Old Mar 8, 2007 | 04:14 PM
jdmsiR20's Avatar
Default Re: (boostedcivicsir)
^that sounds right...
i also read that pusher style is a little less efficent due to the way the blades of the fan are angled.
Old Mar 9, 2007 | 09:43 AM
b18b1turbo's Avatar
Default Re:
thanks guys for all the info...
Old Mar 9, 2007 | 12:21 PM
mike1114's Avatar
Default Re: Re: (b18b1turbo)
edit...nevermind.
EM1 Resto
Oct 10, 2009 10:55 AM
kcjohnnyboy
Jul 4, 2006 03:00 AM
B18EG6
Aug 23, 2005 10:41 PM
rusteds2k
Feb 11, 2004 10:11 AM
