turbo leaking oil, what do you think?
this is the clearest pic i could get.......so what do you guys suggest?
Modified by buttsneeze at 3:00 PM 3/3/2007
Modified by buttsneeze at 3:01 PM 3/3/2007
Modified by buttsneeze at 3:03 PM 3/3/2007
Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 »</TD></TR><TR><TD CLASS="quote">does it burn oil too? I'm guessing the seals are shot. What kind of turbo and how many miles??</TD></TR></TABLE>
nope, i'm pretty sure i'm not burning any oil......the turbo is a turbonetics t3/to4b from a drag kit, only has about 2000 miles on it at the most (probably way less).
Re: (buttsneeze)
Mine used to do that after it would sit after driving it. It would burn off after a few minutes of driving. Running a restrictor at the turbo helped quite a bit for me. With a 3an line.
Most turbo's just use air differencial's too seal it up. On mine the only thing there is a snap ring which holds the shaft in.
Re: (coneheadsracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coneheadsracing »</TD></TR><TR><TD CLASS="quote">Mine used to do that after it would sit after driving it. It would burn off after a few minutes of driving. Running a restrictor at the turbo helped quite a bit for me. With a 3an line.
Most turbo's just use air differencial's too seal it up. On mine the only thing there is a snap ring which holds the shaft in. </TD></TR></TABLE>
Yeah, I only notice it after it's been sitting.......i guess it's not really leaking that much, but it's definitely leaking. my oil level looks good every single time i check it, but then again, i don't even drive the car that much.
by the way, where's a good site to order a restrictor with the line?
any other opinions would also be appreciated......
Modified by buttsneeze at 5:24 PM 3/3/2007
Re: turbo leaking oil, what do you think? (buttsneeze)
I would check the flange that is bolted to the oil drain on the turbo , I had the same problem and mine had a small crack in it , and mine also came with a drag kit , the flange looked like it was a cast peace not machined like the nicer ones ,
Re: turbo leaking oil, what do you think? (B18C1CYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA »</TD></TR><TR><TD CLASS="quote">I would check the flange that is bolted to the oil drain on the turbo , I had the same problem and mine had a small crack in it , and mine also came with a drag kit , the flange looked like it was a cast peace not machined like the nicer ones ,</TD></TR></TABLE>
yeah, i can definitely check that.....especially since that's easy to get to! by the way b18c1cya, my manifold is on and i like it very much. i'll have to send you some pics or i'll probably just post one here......
thanks It took me almost 2 months to figure out where it was coming from , lol and then one day I tried to tighten it and it just let go in my hand no wrench or any thing just hand tight , haha
here's a pic for ya b18c1cya:
by the way, still open for opinions if others want to chime in........
i'm not sure if my line size is already 3an, but it came from the drag kit......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by buttsneeze »</TD></TR><TR><TD CLASS="quote">by the way, still open for opinions if others want to chime in........
i'm not sure if my line size is already 3an, but it came from the drag kit......</TD></TR></TABLE>
does anybody know offhand what size comes in a drag kit?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA »</TD></TR><TR><TD CLASS="quote">yup -3 in the drag kit </TD></TR></TABLE>
then do i even need an oil restrictor? or is it one of them things that "it wouldn't hurt"......?
the gasket for that flange was leaking on mine too,im trying to find the same gasket as a matter of fact because i just twisted my center piece of the turbo to have the oil feed straight up and down with the drain
Re: turbo leaking oil, what do you think? (TurbodTegSfaria)
ok, here's a question.....
Since the oil restrictor will change the oil pressure that the turbo sees, will this change the way the turbo spools? Would it make such a difference that I would have to retune the car?
(sorry, just thought i'd ask out of pure curiousity)
Re: (shortyz21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shortyz21 »</TD></TR><TR><TD CLASS="quote">mine did that, then it stopped..
ditto, pretty wierd
ditto, pretty wierd
Re: (95dxb18c1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dxb18c1 »</TD></TR><TR><TD CLASS="quote">
ditto, pretty wierd</TD></TR></TABLE>
ok, but you guys don't know why it stopped?
by the way, i've just spent half an hour searching wether or not i should use an oil restrictor, and now i'm confused more than before?!? some people say not, some people say to.
what about a -2an feed line instead of a restrictor?
Re: (buttsneeze)
i would def use a restrictor . hondas get alot of oil pressure,i just put a real small restrictor on mine,and it seems to be ok, i already driven the car aboput 30 miles
South Bay Surfer
07-17-2008 10:14 AM
