Piston Comp.
Old Mar 8, 2007 | 07:40 AM
Boostin_GSR's Avatar
Default Piston Comp.
So right now I'm building my motor and it's comming time for me to order up my pistons. I'm going to be doing a 95mm stroker crank and the block is bored to 81.5mm. What kinda of compression ratio should I be shooting for I've I'm looking for high 400's to low 500's?
Old Mar 8, 2007 | 07:49 AM
DaveF's Avatar
Default Re: Piston Comp. (Boostin_GSR)
why stroker ? you can make 500whp on a bone stock longblock.
Old Mar 9, 2007 | 09:54 PM
Default Re: Piston Comp. (dturbocivic)
No replacement for displacement, plus i got some cash to blow..
Old Mar 9, 2007 | 10:38 PM
a1320addict's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostin_GSR &raquo;</TD></TR><TR><TD CLASS="quote">Plus i got some cash to blow..</TD></TR></TABLE>
i wish i had that problem
As for the comment about no replacement for displacement, the gains will be neglible in comparison to the amount of money spent for the crank, matching stroke rods, and machining. Save yourself the money, if you really don't need it and don't care how you spend it...I'm always taking donations.
Old Mar 10, 2007 | 06:50 AM
b18sihatch's Avatar
if i was you i would go with a larger bore and larger stroke if needed, otherwse just keep it stock and put the money into quality turbo parts
Old Mar 14, 2007 | 08:06 AM
Default Re: Piston Comp. (b18sihatch)
I'm rocking a peakboost turbo kit and I have a full 3" turbo back exhaust. I've been buying and storing my parts for about a year now and I've got everything. I came across a really cheap block so I decided I wanted to build a motor as well. The block is bored to 81.5mm, sleeve guards installed, and decked. I'm planning on buying the Brian Crower stroker kit, it comes with everything.
Old Mar 14, 2007 | 08:25 AM
JDogg's Avatar
is it stock sleeves?
if so it wont last but like a week w/that crank in it
SP GARAGE
Apr 12, 2012 02:44 PM
justgotinthegame
Mar 11, 2010 06:47 PM
chueflee
10
Jul 6, 2008 11:19 AM
WVTURBOCRX
Jan 12, 2006 08:58 PM
TURBO B
Oct 23, 2003 04:13 AM
