crank no start
crank no start
ok so i have a 91 crx dx with the 1.5L DPFI.the car cranks over but it wont start.it sounds like it wants to but nothing.i have spark and fuel but the engine is flooding i think.after cranking it for a while the engine backfires thru the throttle body.i have no idea where to start.Any help will be greatly appreciated,thank you in advance
Re: crank no start
Mine would do the same thing after sitting for awhile. Try putting in new spark plugs and turning the engine over 1 revolution at a time with the key and turn key off and repeat and hopefully it will crank. I hope this helps, it did for me.
Re: crank no start
i figured out what the problem was.si i was leaking oil from my dizzy o-ring and i put a new one in.when i did this i guess the tooth that grabs onto the cam moved 180 degress.i was on #4 spark plug when i should've been at #1.turned the dizzy back,put everything together and it started right up.thanks for the help anyways everyone!
idrivecrx
01-24-2006 06:05 PM
