tranny problem
tranny problem
well my car broke last week after having my turbo on for 2days and here is the problem... it all started when my clutch cable broke so i switched it out and after i put the new one on the clutch didnt want to dis engage, so i took the tranny off and found that the throw out spring had come off one side of the bearing. so i replaced both the spring and bearin (new pieces) and threw in a new clutch disc at the same time, bolted everything back up and cranked it. went to put it in gear and same crap didnt want to go in, if i start it in gear and hold the clutch pedal in the car will still move so im thinkin the clutch is still not dis engaging but i the throw out arm is moving all the way.. anyone have any idea's on what this could be?? could it be the pressure plate, the tranny internals??? it will nto go into gear when the car is on regardless of what i do, but it will go in when the car is off...
Re: tranny problem (EF_LSVtec)
it felt just about the same as it did before it broke.... its a act clutch... i tried adjusting it to where the release arm has a little bit of play and to whre the cable is as tight as it could be and no luck
