Z6 sohvtec CAM in a Y8 head ?
will this be a str8 swap? i have a brand new zex 53100 street cam & might get a 96' newer ex..... both sohc... nothing in search... wanna give my next 4dr some cajones
Re: Z6 sohvtec CAM in a Y8 head ? (dremmel)
Zex lists separate cams for the Z6 and the Y8. don't know the difference but i have a stock Z6 cam in my Y8 head so i know that works for a fact.
Re: Z6 sohvtec CAM in a Y8 head ? (ImportHatch)
Its off 5 degrees if you use mismatch the cam and cam gear. That is if you use a d16z6 cam gear with your z6 cam in a Y8 head, your cam timing will not be off. However if you use the Y8 gear with the z6 cam you will have to advance you cam timing 5 degrees.
I've got a y8 cam in my z6 head and need to run 5 degrees of cam retard to get the timing back to stock, because I am using a z6 cam gear. Does that make sense?
Re: Z6 sohvtec CAM in a Y8 head ? (Noahk)
Re: Z6 sohvtec CAM in a Y8 head ? (SlicedBread)
i'm running the Z6 cam because the Y8 cam i had was bad. the end where the cam gear is was all worn funny and the keyway was messed up. my buddy had a Z6 cam laying around and i just put that in. this summer i am getting a Crower cam. i have a skunk2 cam gear and i am running 4 deg ret.
Re: Z6 sohvtec CAM in a Y8 head ? (upstatecrx)
sweet ty 4 responses. I HAD a jdm sohc[zc]vtec motor- head swap 4 smog ref . This zex cam has been collecting dust in my closet...never used yet,spanking new. well that soon2B no-tec zc block car will be sold soon & i wanted 2 know if its usable in a 96up y8....now i know & " knowing is 1/2 the battle" go GI JOE !
ps: might have to get auto/i got mad carpal tunnel....will this cam even be noticed ?
SOHC_MShue
02-07-2004 06:18 AM
