Engine Code problems??
Old Apr 24, 2003 | 11:53 AM
team2n1hatch's Avatar
Default Engine Code problems??
Hey
Im gettin codes off my ecu for a fuel system error, and an injection system error , there was one other code for my vss but thats a different post all together...all together the codes i got were 16, 17, 43...i know the vss is one of them...anyone have any ideas abotu what could be the prob with the other two codes...i swtiched motors from a d15, dpfi, non vtec to a d16z6 vtec, mpfi, and have had no prob for the last couple months then the lights popped on....the motor has about 100, 000 miles on it...what gen probs may have occured to cause these codes...any help is better then none??? thanx
Old Apr 24, 2003 | 11:59 AM
RCautoworks's Avatar
Default Re: Engine Code problems?? (team2n1hatch)
What obd are your running ? If your running obd0 then there is no code 43.
Old Apr 24, 2003 | 12:04 PM
Default Re: Engine Code problems?? (90blackcrx)
im runnin obd1, there was a code 43...my homie is a honda tech but i havent had a chance to talk to him but he off the codes to me
Old Apr 24, 2003 | 12:24 PM
Code 16 - Fuel Injector
Code 16 is probably the Main Relay, however it could still mean a bad Injector, Resistor Box tho.
Most failures occur, when the weather starts heating-up for the summer...
If the car refuses to start, but "turns over" on a hot day, try opening the doors/windows, and let the interior cool down. "Then try starting again". May not work all the time, but worth a try anyway. Also, would help in troubleshooting the prob, if it does start. Another place to look is the ECT sensor, refer to the above
And code 43 is fuel supply system defective or malfunctioning fuel supply system
Old Apr 24, 2003 | 01:21 PM
bump
shawn69
Engine Management and Tuning
Aug 16, 2009 10:01 AM
turboxsi
Jun 18, 2004 10:24 AM
turboxsi
Nov 18, 2003 05:39 PM
Herminator
Jun 28, 2003 03:45 AM
