Help on b16 alternator belt
I broke my alternator belt on my crx and when i went to replace it i got a belt for a 00 civic si and it was to wide but we made it work because i was out of state and needed to get home. Well on the way home that snapped off because it was to wide. What kind of belt do i need to get for my car.
Re: (95VXFRANK)
Just out of curiousity, which is the B16 belt that is an inch shorter and makes for not having to dent in the frame rail? I dented mine in and it worked out great but I'd like the added insurance that it's short too.
Re: (beta13)
Well last night i tried a 91 integra ls belt but it was to wide to. I have 3 ridges on the alternator pulley and 4 on the other pulley. So what belt should i get? My car is eating belts like there swiss cheese.
MEAT PATTY
Re: (HondaDriver85)
I had the same problem of eating belts. And I finally went to the dealer and got a civic si (dohc) belt. I believe I had to change the pulley on my alternator because of the same issue you had with 3 ridged belt opposed to the 4 ridged belt.
Re: (raene)
well if you have the original one you snapped then you could bring it there and compare...otherwise a 94 del sol dohc should work fine. haha mine looks bad i have a chunk missing but it hasnt snaped yet....also check out your pully maybe something wrong with it
Import_Dumbass
10
05-21-2006 03:59 PM
