NEED B16a distributer wire colors, and pinouts>>>HELP<<<<<<
There is a orange and white wire and a orange and white with a stripe then two blue wires and a white wire. Where do these all plug into on my Stock DX 89 harness, for B16a swap???? I think that the orange and white wires plug right up to my stock harness. If so does the single white wire also connect... Where do these all go in the ECU,,,,,I have to do it manually( run seperate wires dirrectly into ECU) after a big mixup in wire harness. I think that I rewired it correctly, but now I am getting no spark when I try to start up. So I just need some wiring info so I could check to make sure I did wiring right!!!!! Everything else is in order,,,what could be the problem?
hondaZvic
04-22-2004 12:51 PM
