zc distributor code 9 problem Knowledgeable help needed
Old Jun 23, 2003 | 06:37 PM
VTgringo's Avatar
Default zc distributor code 9 problem Knowledgeable help needed
I have an 89 crx si with a zc engine installed. I just installed a new distributor that checks out to spec. i checked the cyp resistance across the distributor and came up with 400 ohms, within spec. my problem is that when i check for that resistance across the ecu harness pins number c1 and c2 i am coming up with 1000 ohms, which is the resistance to the crank angle sensor. I tried switching these wires so that i had the 400 ohm resistance across pins c1 and c2 and the car wouldn't even start. I appreciate any help or advice given.
Old Jun 23, 2003 | 06:43 PM
turbo sol's Avatar
Default Re: zc distributor code 9 problem Knowledgeable help needed (VTgringo)
i am not sure how you went about everything, but i had the same code and it was because i had the white wires switched around. check those out. and all of your dist wiring.
thats my thought
Old Jun 23, 2003 | 06:53 PM
VTgringo's Avatar
Default Re: zc distributor code 9 problem Knowledgeable help needed (turbo sol)
turbo sol, im pretty sure i got those wires right, i checked them a few times the other day. Was your car idling very poorly when you had those wires crossed?
anyone else with suggestions?
Old Jun 23, 2003 | 06:59 PM
crx(gator)'s Avatar
its not in the distributor...its the exhaust cam angle sensor...its the wires that you had to extend from the distributor wiring clip...
turbo sol's Avatar
my car wouldnt even start with the wires wrong, so maybe its something different with yours?
Old Jun 23, 2003 | 07:28 PM
VTgringo's Avatar
ttt..........help appreciated!!
Squeek485
Jan 26, 2017 10:54 AM
90si-rex
17
Jul 7, 2011 11:56 AM
XplicitzOldSkoolDA
10
Aug 19, 2008 06:51 PM
Eresuncabron
Aug 12, 2004 01:01 PM
typegsr
Apr 29, 2003 06:02 PM
