FAQ: MPFI swap information
Can anyone explain how to do a mpfi swap??
Ok io got a 88 civic dx hacth.I got that junk dual port i wana do a mpfi swap.I got
Si harness
crx si head and intak manifold
Resister box
1988 crx si ecu.
I just want to know i just plug and play or will i have to tune stuff?
Thankjs guys i tried searching didnt really find anything helpfull.
Si harness
Resister box
1988 crx si ecu.
Skoobie no more...
Re: Can anyone explain how to do a mpfi swap?? (sp00nvtec)
u tried searching ? I doubt it i just did a mpfi swap a month ago and i found all info on this site. i just pulled 277 results when i searced for mpfi.
anyways go to
http://tech.hybridgarage.com/t...g.htm will answer all your questions.
anyways go to
Re: Can anyone explain how to do a mpfi swap?? (90Sicvic)
You are going to have to mate parts of the Si harness to your stock DX harness. If you need one built then let me know.
something different
1 Post
Re: Can anyone explain how to do a mpfi swap?? (JDMCivicEF9)
its a super easy job. you can do the mpfi swap without chaning the head at all it you want to. some people swear you cant do it without swapping cam/cam gear,but you can. you need the intake manifold, distributer, and all the injectors/fuelrail/throttle body for the si. put that stuff on, do the wiring swap(simple) and plug in the mpfi ecu and your done. for the wiring, you'll need to run 4 wires through the firewall(go through where the ac lines normally do, if you dont have ac, you'll have a rubber plug in the spot). those 4 wires need to be tapped into some stuff, i'm not goin into it right now though, you can search for that sort of thing yourself. its really not difficult.
I'm going to be doing the DPFI->MPFI conversion soon and it's the wiring I'm still sketchy on. I've searched the site, done the links but I'm just iffy on the whole wiring portion. I guess I'll figure it out as I go hahaha
Re: Can anyone explain how to do a mpfi swap?? (88DXCRX)
New to the site Im doing a mpfi sowap on my DX. I have ben reading and it seid that I can get the wires from the cilender position sensor out the stooc distributer but what coller are theyand in what order do they go thanks.
Re: Can anyone explain how to do a mpfi swap?? (Adrian69)
Hey I need help! I have been searching for about a month. I got all the parts for mpfi swap. I put everythinng in and I followed the instructions but the car is all retarted. It doesn't want to stay on! And the check the engine light stays on. PLEASE HELP!!!
New User
holly **** you attempted the mpfi swap before learning to type......
what computer are you running? have you checked to see WHICH codes it's throwing?
have to tried another resister box? maybe yours is bad. same with injectors.
I'm running a pm6 ecu from a 89 civic. I haven't checked the codes. How do you check the codes?Should i get new injectors and resister box?
1 Post
If you dont feel 100% confident, have rywire do it for you http://www.rywire.com
Ryan
Ryan
New User
9* Accord 85-98** Civic 86-98 CRX 85-91 Del Sol 93-97 Prelude 85-98
Cylinder Position (CYP) Sensor
Defective cicuit or unplugged/defective sensor
*N/A to any throttle body injection Honda's
**N/A to V-6 engines
14 Accord 88-98 Civic 88-98 CRX 88-91 Del Sol 93-97 Prelude 88-98
Idle Air Control (IAC) Valve
