help b16
help b16
dam the 94 delsol vtec dohc waterpump aint working its not fitting i need help, what other water pump should i use..its like way off need help.. b16a pr3 printed on alot of things thats my motor...
Location: I told you to wait in the truck in Texas, United States
Re: help b16 (90hbvtec)
Member "Monty" gave me this info and it was accurate for everything I replaced:
Water Pump 19200-P30-003 94 - del sol
Head Gasket 12251-P30-014 94 - del sol
Oil Control Orifice O ring 15142-PH3-003 94 - del sol
Intake Manifold Gasket 17105-P30-004 94 - del sol
Exhaust Manifold Gasket 18115-P30-013 94 - del sol
throttle Body Gasket 16176-PR3-010 90-91 integra
Pcv valve 17130-PM6-G01 94 - del sol
Timing Belt 14400-PR3-004 94 - del sol
Alternator Belt 31110-PR3-003 94 - del sol
Tensioner 14510-P30-003 94 - del sol
Thermostat 19301-P08-305 90-91 integra / 94 del sol (same)
Connecting Pipe O rings (2) 91314-PH7-003 90-91 integra / 94 del sol (same)
Cap & Rotor Assembly 06303-PR4-000 90-91 integra
Rotor (If needed seperately) 30103-PR3-016 90-91 integra
Clutch Cable 22910-SK7-A02 90-91 integra
Throttle Cable 17910-SK7-A03 90-91 integra
Cam Seals (2) 91213-PR3-004 94 - del sol
Oil pan seal 11251-P30-004 94 - del sol
Oil Pump (comes with crank seal) 15100-PR3-024 94 - del sol
Oil Filter 15400-POH-305 94 - del sol
Oil Pick Up Gasket 15221-PW0-S01 94 - del sol
Shift linkage bushing 54303-SB2-010 90-91 integra
crank seal 91212-PR3-003 94 - del sol
rear main seal 91214-PH1-004 90-91 integra / 94 del sol (same)
Valve cover grommets (8) 90442-P30-000 94 - del sol
Spark Plug O rings (4) 12342-P66-000 94 - del sol
Rubber plug for exhaust cam tranny side 94 - del sol
Spark Plugs (4) BKR6E-N11 NGK
Spark Plug Wires 32722-PR4-A01 92 - integra gsr
Upper Radiator Hose 19501-PR3-000 92 - integra gsr
Lower Radiator Hose 19502-PR4-A00 90-91 integra
Bypass Hose (Thermostat) 19508-P08-000 94 - del sol
Washer for coolant drain on block 90401-PR4-000 94 - del sol
Re: help b16 (1991_jdm_sleeper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1991_jdm_sleeper »</TD></TR><TR><TD CLASS="quote">same **** happened to me i asked for a dol sol dohc vtec water pump and the ******* gave me the sohc vtec si waterpump....So double check it.... </TD></TR></TABLE>
Yeah, I would double check it to see if he gave you the right one because a 94 del sol VTEC h20 pump will should work.
Re: help b16 (hybrid honda)
will the 92 integra gsr w/p and the 99si work let me know i order 3 diffrent kinds of wather pumps 99si,b17 92 gsr, antoher 94 delsol from carquest hopfully one of hte 3 will work
SeaBass
05-31-2003 03:48 PM
Monty
09-07-2002 05:41 AM
