CV boot maintenance?
Is there anything I can do to prevent changing CV boots every 2 years? Also, is this typical for lowered Honda's?
The car is lowered on H&R Race springs and Tokico blues, which bring it down 2.5 inches.
Re: CV boot maintenance? (ef8mugen)
what type of boot are you using? the quick boot with the splits down the middle or are you using the full sealed boots? the split boots are junk and you will have to replace them every 2 years they dont last. It is best to use the full boots like the oem style. they last much longer than 2 years.
Re: CV boot maintenance? (Donkey85)
If the full sealed boot is OEM, then that is what I use.
I have had problems with every Honda I owned.
Is there an aftermarket boot that is stronger?
I'm DEFINITELY wondering the same thing myself because my passenger side boot just ripped on me and I need to get it replaced asap.
Get a CV boot kit from the parts store shood be good for more than 2 years. I tore up some stock ones when my car was lowered, and just got new ones, and works fine for me.
Re: CV boot maintenance? (UPS)
orielly sells a boot kit w/ everything you need for 8 bucks per boot. grease, clamps, and all... just take the axle off take it apart and put on the new boot then reinstall. ive never heard of any way to keep it from ripping
i had to replace a boot last year and havent had any problems since. the orielly boot seemed to be a bit more heavy duty than the stock one too.
Re: CV boot maintenance? (90civichbsi)
Here's a well-kept secret...
http://forums.s2ki.com/forums/...13452
Modified by Seks at 5:38 PM 11/2/2003
Re: CV boot maintenance? (Seks)
so really the reason why these boots typically rip is because they dry out and crack? How much does it usually cost to buy new CV upper boots?
Re: CV boot maintenance? (Hybrid Invasion)
they make polyurethane cv boots... they are real badass... they have them at autozones around where i live... i think energy suspension makes them... im sure those things would outlast the axle
Joelrz
12-07-2006 06:38 AM
