Horrible B16 Gas Milage
Hey guys my b16 has some suck *** gas milage. I have changed the plugs and air filter but it still only gets like 21-23mpg. I want any and all the reasons this could be goin on, thanks for your help
Re: Horrible B16 Gas Milage (teler86)
New o2 sensor(s)
Fuel filter
Oil change/filter
Make sure tires arent underinflated
Fuel injection cleaner
That tornado thing really helps to ..
And check for vacuum leaks ,,because a leak will get you shitty mpg..
Fuel filter
Oil change/filter
Re: Horrible B16 Gas Milage (doublethink)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublethink »</TD></TR><TR><TD CLASS="quote">haha, stop running it into vtec at every traffic light, no matter how fun it is. </TD></TR></TABLE> And the truth comes out.
Re: Horrible B16 Gas Milage (black90si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black90si »</TD></TR><TR><TD CLASS="quote">Pick your foot up off the throttle. </TD></TR></TABLE>
Exactly! I thought you said "horrible" gas mileage?
Location: Come back next year and Ill put some, eggnog in your face, US
I know how you feal, my B16's gas milage was always up and down. It was not because of a lead foot. Now that I have a crv-tec in there the gas milage is always bad. The next thing for me to buy, to solve this gas thing it a fuel control. I will let you know if things get any better.
Re: Horrible B16 Gas Milage (NCivicsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NCivicsi »</TD></TR><TR><TD CLASS="quote">does that tornado thing really work?</TD></TR></TABLE>
Damn right..
Put it in my fathers car and he got about 7-10 more mpg..I doubt if he got any power but it does help with gas milelage..
Damn right..
it works till it falls apart on you,
that **** is put together so shitty that it breaks really easily. id check your fuel return lines and your fuel feed lines going into the fuel rail, you might have a leak, i was leaking gas after my turbo setup, i was getting about 8mpg
Re: Horrible B16 Gas Milage (slowpokesi)
I notice the same with my b16 but you know what it is? gearing. you jump on the freeway for a good mount of time there goes ur gas. 4k rpms at 70? yea. so about 23mpg sounds pretty close.
damn 4800? u go like 13's with 40 series tires or something? I have the stock crx si wheels and tires and i sti right on 4k at 70mph and at 4800rpm i dont know how the hell ur getting 30mpg? Thats crazy! in my ls crx i got 31.9 average everywhere driving.
Re: Horrible B16 Gas Milage (KFBhonda)
i can get 35 mpg in my crx gsr with uberdata. I'm running 15.1-15.5 a/f partial throttle and if i never hit vtec it does pretty good. But even if i do i still get 27 mpg. Time for some partial throttle tuning. I dont even run a o2 sensor no more i just started tuning it myself as weather changed. I run a little lean but i have no detonation problems or anything the car runs like a champ. K Maybe its time to bust out some turbo edit or uberdata and show that ecu who is boss...just a suggestion. I know its not for everyone buts its worth a try.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowpokesi »</TD></TR><TR><TD CLASS="quote">b16 with a j1 tranny, its uses the same gearing in the 96-97 itr trannys</TD></TR></TABLE>
I have a ys1 with even shorter gears than a j1 and I'm running 13's with 40 series tires and at 70mph i'm at like 4100-4200 rpm. edit: nvm if you stay in 5th gear a j1 is higher. btw I get 30+ mpg on the freeway and 24 or so when I rip on it.
Re: Horrible B16 Gas Milage (michaelOlson)
hey i'm not a leadfoot my car goes up to 3500rpm at the max, so the leadfoot thing isnt my problem, however i do think my vacum lines are screwed up, i will post a pic to show u guys what i mean, maybe one of you will know which lines are screwed
when im in boost lol the gas gauge moves as fast as the speedometer, then when i let off it goes back to normal
its pretty entertaining.
Re: Horrible B16 Gas Milage (93CX)
remember its 1.6 don't mean it will save gas.
I had some badd gas mileage with my b16b maybe cause of my supra fuel pump. but anyways I have a si now now this baby saves some major gas.
fill up was 10gal like nearly 20bucks.
regular 88.
regular 88.
BLUE EH3
06-18-2004 04:59 PM
