Is my exhaust BAD???
I was driving home after school then my CRX started to act scary!!! I was first driving around 40mph then the exhaust started to make this popping sound then when I come to a complete stop at a red light the RPM is moving up and down around 1000RPM. The engine was also making a wear noise. It continued to sake then stop many time. I was in neutral so I press the gas to make sure if everything was OK but when the light turn green, my REX moves very slow and hear all this noise from my exhaust. I try pressing the gas in 1st to 2nd gear but it make a sound like if my exhaust was back firing. I got scare so I park at the side of the street then check the engine. The only problem I found here was that my air intake was off but I think that doesn’t do anything with the exhaust. I rev the gas all hard many time then start to drive then there wasn’t any problem. The only thing I could think of is that the cat or some where in my exhaust is clogged up? Any idea what’s wrong???
Re: Is my exhaust BAD??? (boosted_hatch_216)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_hatch_216 »</TD></TR><TR><TD CLASS="quote">idle air control, try cleaning it and that should do the trick. </TD></TR></TABLE>
HOW??
HOW??
Re: Is my exhaust BAD??? (kim_2_da_chee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kim_2_da_chee »</TD></TR><TR><TD CLASS="quote">I think it's something as simple as a hole in your exhaust. (For the loud back firing sounds)</TD></TR></TABLE>
But does that slow down your speed? I mean the car didn't even go 20mph and it was shaking craze like it was knocking. My friends REX had a hole but his car was running strong before he killed his stock motor.
