1.5 5speed conversion to 1.6 what do i need?
I just started this project and have only a little know how about cars but trucks are my thing, there isnt a whole lot diffrent except the drive train and minnor things.
i have a 1.6 but what tranny do i need to bolt up? *5 speed tranny*
i asume the ecu is garbage so what ecu do i need?
basicaly if there is anyting that will be diffrent between 1.5 and 1.6 that isnt obvious what is it?
Re: 1.5 5speed conversion to 1.6 what do i need? (SlitUrNek)
it will bolt to the tranny you have. alot of d series parts are interchangeable there not much of a difference between the two motors except for the power gains. what motor are we talking about here?
i am almost 100% positive that it is from a 91crx si with auto tranny im asuming its a b16?
ok i finnaly found a motor guide and it sais my 1.5 is a D15B6 so that would make my tranny what?
Modified by SlitUrNek at 4:46 PM 8/28/2005
Re: (SlitUrNek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlitUrNek »</TD></TR><TR><TD CLASS="quote">i am almost 100% positive that it is from a 91crx si with auto tranny im asuming its a b16?
ok i finnaly found a motor guide and it sais my 1.5 is a D15B6 so that would make my tranny what?</TD></TR></TABLE>
The 91 CRX Si has a d16a6, not a b16.
D15B6, means you have a crx hf, nice choice. You already have MPFI, so you do NOT have to convert to MPFI.
As far as 1.6 swaps: If you are going to use the engine from a CRX si (D16A6), you can use the transmission in your car now, or I would suggest getting the transmission that comes with the A6 because the A6 transmission is shortered geared meaning better acceleration. Use your stock mounts (if they are worn out, buy new ones). You will need a PM6 ecu. Use the A6 intake manifold/exhaust manifold. You can use your Hf distributor on the A6, or the A6 one. I would suggest getting a new timing belt, water pump, tensioner, spark plugs and plug wires on the new A6. I could go on, but search on the A6 swap.
The B16a1 swap. You can also search on these swaps into an Hf.
sweet thanks, i am looking into selling my 1.6 now and going with the D16A8/9, just a bit more power so i have found on a few spec sheets thank you very much guys you have been a very big help
Mark D. Surface
05-08-2007 04:58 PM
crxsir29
08-30-2005 05:58 PM
Layziebtnh055
03-16-2004 08:52 AM
