tranny leaking
tranny leaking
I have a problem with my ls cable trann it leaks oil from driver side I change the shaft seal but it still leak when I hit the pedal to the metal ...lol I might be thinking can the half shaft have to do somthing with it leaking I have the del sol vtec half shaft can somone help?
Re: tranny leaking
sounds to me like you have the wrong seal in the transmission - you need the seal for the 94-00 transmission - the 90-93 intermediate shafts are different diameter from the 94-00 - if you use the 90-93 intermediate shaft with the female outer end, you use the 90-93 seal - if you use the 94-00 intermediate shaft with the male outer end, you use the 94-00 seal
Michael Hall
04-06-2018 08:49 AM
