Brake caliper play. Is it normal?
Old 04-20-2013, 04:40 AM
EFing8's Avatar
Default Brake caliper play. Is it normal?
If i reach through the spokes of my rims and grab the top of the caliper (floating part), I can wiggle it up and down and it makes a slight clank noise.
are my slide / guide pins worn out causing play?
if i'm coming to a stop light and hammer the brakes at slow speed i get a shudder through the car.
thanks!.
Old 04-20-2013, 07:43 AM
Spug's Avatar
Default Re: Brake caliper play. Is it normal?
They're cheap, replace them, sounds like it's time.
Old 04-20-2013, 08:25 AM
bbarbulo's Avatar
it's not normal
Old 04-20-2013, 09:35 AM
EFing8's Avatar
I wasn't sure, i replaced both of them about... ummm... 5 years ago. Guess there's a good chance that it's time again huh. Shame, all the sliders and everything move freely.
Old 04-20-2013, 09:41 AM
EFing8's Avatar
Not my video, but this is pretty much what mine are doing...
Old 04-20-2013, 09:57 AM
bbarbulo's Avatar
mine don't do that... well only right after i retracted the pistons in order to change the pads or something. as soon as I apply the brakes the first time it goes (and stays) tight.
Old 04-20-2013, 12:04 PM
EFing8's Avatar
so new calipers it is then... lame.
driver side is much worse than passenger side. i think i'll do the one and then see how that goes. if it's tight tight like you claim, i will do the other side.
Oknoe.
04-21-2010 04:10 PM
dragracer7383
11-29-2006 05:14 AM
highwayman
08-08-2005 07:12 AM
ZexyAccord
10-20-2004 10:36 AM
Lazydsm
12-09-2003 08:35 PM
Quick Reply: Brake caliper play. Is it normal?
