no fuel?????
Old Jun 20, 2006 | 07:28 PM
90civSi's Avatar
Default no fuel?????
ok so i just got the new dizzy in my car drive it for a day and now all of a sudden it wont start. we check for spark and have it, checked the fuel and we have it up until it gets to the fuel rail then after that it doesnt seem like it is getting put through the injectors? it has to be some kind of electircal something to cause it, could it be the relay? the dizzy? what could be the cause of not getting the fuel???
Old Jun 20, 2006 | 07:58 PM
hatchinprogress's Avatar
Default Re: no fuel????? (90civSi)
if your not getting fuel past the injectors (but you know its at the rail).....make sure injectors are clean and not clogged(if clean)....check to make sure your getting power to the injectors
Old Jun 20, 2006 | 08:05 PM
90civSi's Avatar
Default Re: no fuel????? (hatchinprogress)
what could casue the injectors to not have power??? or whatever you might say about them not working?
Old Jun 20, 2006 | 10:25 PM
90civSi's Avatar
bump for some help
Old Jun 20, 2006 | 11:22 PM
Dohc 4door Rye's Avatar
Default Re: (90civSi)
take the fuel rail off and aim ur injectors up and see which one or two that don't shoot gas if its one it can be clogged or maybe your wiring came undone.... if all of them don't work then i can't help you there 8( it can possibly still be wiring so i would double check that regardless
Old Jun 21, 2006 | 06:39 AM
90civSi's Avatar
anyone else for the electrical side of it ????
Old Jun 21, 2006 | 02:09 PM
90civSi's Avatar
bump this up
Old Jun 21, 2006 | 07:27 PM
90civSi's Avatar
theres gotta be someone out there with some kind of info?
Old Jun 21, 2006 | 09:35 PM
IndySporty's Avatar
try a known good ECU and then a known good Dizzy. You know your wiring is right because the car already ran for a whole day. Of course you've already checked all fuses right?
Old Jun 22, 2006 | 12:23 PM
integra95gsr's Avatar
Default Re: (IndySporty)
can someone explain or get me a picture of were the relay for the injectors are cuzi think thats the problem but i dont know where it is located???
on a friends name
Natural Aspirations
Feb 23, 2015 02:58 AM
slamedcivic
Nov 2, 2006 02:49 PM
allmotor.net
Sep 27, 2004 11:57 AM
Sinner
Jun 8, 2003 03:03 PM
Sinner
Jun 6, 2003 02:25 PM
