Old 03-25-2015, 11:32 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
Power Surging, Dash-Lights Flicker, no starter signal! HELP!!!
Old 06-18-2006, 11:25 AM
Jesse253's Avatar
Default Power Surging, Dash-Lights Flicker, no starter signal! HELP!!!
Drove my CRX home. Worked fine. Went to start it up for work the next morning, nothing from the starter, wouldn't even turn over and my dash lights pulse now. Seems to be a power surge of some sort. I replaced the strarter thinkin' that was it. Nope. My wires are fine. For about a week before I was throwing a code 7 on my ecu but I highly doubt that to be the problem for the surge. Any help would be appreciated. It's a 1989 CR-X HF 1.5l SOHC. Email is OrtingSucks@Yahoo.Com
Old 06-18-2006, 11:27 AM
SiR Inspired ED7's Avatar
Default Re: Power Surging, Dash-Lights Flicker, no starter signal! HELP!!! (Jesse253)
code 7...you sure your starter is grounded correct?
Old 06-18-2006, 02:27 PM
civicwagonman's Avatar
make sure your ground from the body to trans and body to valve cover are good.
Old 04-21-2008, 04:19 PM
civicman98's Avatar
Default Re: (civicwagonman)
Mine is doing the same thing with the dash light pulsing and the main relay clicking. I'm also not getting no voltage to the stater signal wire from the main relay and the fuse for the starter signal is good also but not getting anything from there either.
Old 08-01-2008, 06:27 AM
sleepycivichb's Avatar
Default Re: (civicman98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicman98 &raquo;</TD></TR><TR><TD CLASS="quote">Mine is doing the same thing with the dash light pulsing and the main relay clicking. I'm also not getting no voltage to the stater signal wire from the main relay and the fuse for the starter signal is good also but not getting anything from there either.</TD></TR></TABLE>
My car just started doing the same thing. If I push start the car it will run (it's how I got it home) battery and alternator are perfect it seems just like the ignition and power charge harness isn't connecting properly with the main relay. HELP!
Old 08-25-2008, 03:22 AM
Default Re: (sleepycivichb)
bump for an answer...
Old 05-15-2009, 09:12 AM
brent2000's Avatar
i have a 2000 civic and my speedometer went dead and the dash lights started pulsating and when i turn the ac on the blower pulsates with the dash lights, my headlights do it as well and its all synced so it dose it all at the exact same time. i thought it was the cpu or the alternator not holding a proper charge ...
Old 05-15-2009, 10:12 AM
88_acED6's Avatar
ok here we go
i had the exact same problem my battery hit my hood causing the symptoms you all are describing.....
make sure all your grounds are good and get a new fuse box.......ELD can go bad and it tells the alternator how much power to put out causing everthing electrical to go crazy.....its the little black box with a 4 wire plug going into it...this thing
88_acED6's Avatar
make that 3 wires
Old 05-15-2009, 11:00 PM
brent2000's Avatar
thanks bro i will try that i alos might of thought it might be the blower relay or the speed sensor, i replaced the speed sensor but to find out the wires to the connector were cut i wired em back no luck... but i will try and get that eld thing about how much??? also i have a 2000 ex auto cluster cumming in might it be the cluster??? never the less i will deffinatly go get on of those...
Old 05-16-2009, 12:02 AM
88_acED6's Avatar
you can find fuseboxes on ebay for about 10 15 buck and there usually in a lot better shape than if they were from a salvage
Old 08-26-2009, 08:05 AM
klungemonger's Avatar
I am having this exact problem right now, wondering if you fixed it and what ended up being the problem? was it the ELD or something else?
Also if someone else reads this bump maybe you can add some fresh perspective or experience...
Old 08-26-2009, 08:35 AM
solorex's Avatar
Sounds like none of you have your grounds connected properly. Check thermostat ground, trans ground, and valve cover ground.
Old 08-26-2009, 09:23 AM
I know for sure those are all hooked up good, I cleaned them and used a light coat of electric grease on them when I reinstalled them. My fuel pump also pulses in time with the dash lights. Any chance it is the alternator or eld? I haven't checked grounds inside the car yet so still have to rule those out.
WarrenPeas
02-24-2013 11:29 AM
Sleeper91
05-31-2010 12:16 PM
sirrex1990
05-13-2010 06:29 PM
ahem ahem
08-23-2009 06:28 PM
Junkyard2000
07-04-2005 10:55 PM
Quick Reply: Power Surging, Dash-Lights Flicker, no starter signal! HELP!!!
