90-91 tails
Re: (661rex89si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 661rex89si »</TD></TR><TR><TD CLASS="quote">silver_ rex is right its not rocket science just transfer the harness over to the 90-91 tail lights and presto they work end of thread.</TD></TR></TABLE>
X2
X2
Re: (harmonator84)
You need to use the 90-91 harness and only use 3 bulbs. The 88-89 have 3 holes (1 reverse, 1 brake and 1 turn signal) for lights and the 90-91 have 4 holes
(1 reverse, 2 brake and 1 turn signal).
Re: (crx!go)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx!go »</TD></TR><TR><TD CLASS="quote">ok where does this harness plug into is it as simple as plug and play</TD></TR></TABLE>
Yes...
Have you ever changed a tail light bulb? If yes, then the wires that you pull out of the tail light housing are part of the tail light wire harness.
This harness unplugs from the main harness.
It is VERY VERY simple...
1) Get the new tail lights
2) Take off your old tail lights
3) Remove the harness/bulbs from the new and old lights
4) Put the old harness/nulbs on the new tail lights
Yes...
71.123.131.10 BANNED
ok first of all all of you were wrong i had to take the old lights cut off the connectors of each and rewire them to the 90-91 the 88-89 have diff connectes then 90-91 and would simply not plug and play...
EFSS153
Re: (crx!go)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx!go »</TD></TR><TR><TD CLASS="quote">ok first of all all of you were wrong i had to take the old lights cut off the connectors of each and rewire them to the 90-91 the 88-89 have diff connectes then 90-91 and would simply not plug and play...</TD></TR></TABLE>
n00bs who don't punctuate give me a headache.
Re: (NAallTheWAY)
Um.... when I put 91 tails on my CRX I used the 88 harness and just attached the bulbs in place. There was no modification necessary. I just took out the old tails, put the new ones in and everything was fine.
CRX Forum
CRX Forum
Re: (crx!go)
Jeez.... did not read read anything above?
1 Post
Re: (crxforum)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxforum »</TD></TR><TR><TD CLASS="quote">Um.... when I put 91 tails on my CRX I used the 88 harness and just attached the bulbs in place. There was no modification necessary. I just took out the old tails, put the new ones in and everything was fine.
CRX Forum</TD></TR></TABLE>
me 2! I think i swaped Left to Right and Right to Left though so they would go on all the hold downs and what not.
Its been 2yrs since i changed mine, but i remember something w/ the swap left and right
Re: (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si »</TD></TR><TR><TD CLASS="quote">
Its been 2yrs since i changed mine, but i remember something w/ the swap left and right </TD></TR></TABLE>
Ive been rocking my tails since 2000 and had no problems. I dont know what the discussion is about. Put them on, plug the bulbs in. Test it out. Go driving.
CRX Forum
CRX Forum
Re: (ludesrv)
Me to
Me to
Re: (ludesrv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv »</TD></TR><TR><TD CLASS="quote">I think Mike is right. The CIVIC need the 90-91 harness.</TD></TR></TABLE>
Im am right. The 90-91 Civic Tails are not the same on the inside as the 88-89 ones. But the CRX ones are.
CRX Forum
CRX Forum
Re: (crxforum)
By chance does anyone have a spare harness? I have 88 tails on my 90 DX and the old tails were altezzas that i sold so i dont have the harness unless i custom wire it (which isnt a big deal) PM me if you do
Re: (crx!go)
you guys dont need to cut anything, just pop the pins out of the little plastic connector with something sharp like a nail. Then pop those pins into the matching plastic connector and you should be good to go. Or you can do like i did, i did not have matching plastic connectors so i popped all pins out and then matched colored wires and taped them together, no cutting or soldering needed.
Re: (crx_88_si)
I'm confused, seems like some are talking about a Civic and some are talking about a CRX, is that what is going on? I don't have the problem but a definate answer would be nice for future reference. I have an89 CRX and a 91 Hatch, who knows what I might try to swap between the two, and I'M sure correct answers will help MANY Honda lovers. Don't make me take my cars apart to find the answer, someone has done this so give them the answer.
PinoyDelS0l
05-07-2009 11:39 PM
CRX5Z
03-30-2006 08:49 AM
CRexcellence
22
07-02-2004 05:12 PM
XEF-9X
10
12-18-2002 06:37 AM
