Problem with relay
Re: Problem with relay (nihad)
almost sounds like you may have a line shorted or coming loose between the ecu and relay. a voltage meter can help you out, check for non ground lines to have continuity to your chassis ground.
Re: Problem with relay (Andy R)
I figured it out it was the ground on the thermostat i got confused and for got to bolt it up I have had some problems with the wiring on my car i had to pull the whole harness and had to test it out side and then put it back in side. I think it had a bad ground some where Also my left cluster turn signall blew on the cluster gauge on the back. It burned out like a fuse. Not sure it there is any diff with a nippon denso or the one i have a nippon seico.
anthonylee29
01-29-2006 07:40 PM
