need help w/ Oxygen sensor
Old 06-11-2007, 07:02 AM
dougshatch's Avatar
Default need help w/ Oxygen sensor
i swapped Vtec D15 obd1 and change the mpfi to dpfi and i cant get em idle right does that becase o2 sensor isnt connect at all? i have 1 wire from obd0 o2 sensor and d15 obd1 has 4 o2 sensor wires, how can i converted it?
Old 06-11-2007, 11:28 AM
Technical Hero
HondaPartsHero's Avatar
Default Re: need help w/ Oxygen sensor (dougshatch)
what ECU are you using?
Old 06-11-2007, 04:30 PM
dougshatch's Avatar
Default Re: need help w/ Oxygen sensor (HondaPartsHero)
PM9 ECU
Old 06-11-2007, 05:32 PM
Crx Jimmy's Avatar
are you obd1 or obd0?
Old 06-11-2007, 05:37 PM
dougshatch's Avatar
Default Re: need help w/ Oxygen sensor (Crx Jimmy)
obd0 i swapped D15 Vtec but i change the mpfi to dpfi
Old 06-11-2007, 06:23 PM
Technical Hero
the PM9 is obd0 so it only looks for a one wire O2, you can't convert it unless you have converted to OBD1
Old 06-11-2007, 06:26 PM
dougshatch's Avatar
i know i have 1 o2 sensor wire and how can i converted it to obd1 o2 sensor cos it have 4 wires
Old 06-11-2007, 06:38 PM
dougshatch's Avatar
or i can buy the obd0 o2 sensor and it would be fine is that right?
hYbRid_Eg6
08-08-2010 09:07 PM
civtegra_hybrid
09-14-2004 01:15 AM
Quick Reply: need help w/ Oxygen sensor
