installed jumper harness and car will not turn on. please help!
i have a 92 gsr in a 90 crx. i installed a vtech controller before i had the jumper harness.could this be the problem why my car will not start? any ideas would be a big help!
Re: installed jumper harness and car will not turn on. please help! (Tank INC.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tank INC. »</TD></TR><TR><TD CLASS="quote">i have a 92 gsr in a 90 crx. i installed a vtech controller before i had the jumper harness.could this be the problem why my car will not start? any ideas would be a big help!</TD></TR></TABLE> You can't use Vtech to control your car, the signal has no way connect to your lan line...
Does your car crank?
Do you have spark?
Do you have gas?
etc...
Do you have spark?
Do you have gas?
etc...
Re: installed jumper harness and car will not turn on. please help! (DC_RaceR)
put the car back to the way it was when it was running, if everything works good that the vtec controler is causeing problems.
my car runs and the controller works. but when i connect the jummper harness and the correct ecu the car will crank but not start. what do i need to rewire the dizzy?
is your CEL coming on when it wont start.
do you know if the ecu was okay before, or can you get another ecu to test
are you switching from obd0 to obd1?
edit: wow a 92 gsr! dont see those everyday
Re: installed jumper harness and car will not turn on. please help! (grog)
yeah im obd 0 im switching to obd1. do i have to rewire my dizzy to obd 1 ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tank INC. »</TD></TR><TR><TD CLASS="quote">yeah im obd 0 im switching to obd1. do i have to rewire my dizzy to obd 1 ?</TD></TR></TABLE>
That's your problem junior.
Do a search there are plenty of topics on switching form OBD0 to OBD1.
no ****, man youngsters when ur switching from OBD 0- to OBD 1 you change O2 sensors, ECU, Dizzy, and jumper harness. did you search prior to the mod.
JDM Approved
03-01-2007 12:48 PM
JDMlyfestyle
10-21-2005 03:49 PM
