obd0-obd1 engine harness?
ok well i have a 88 si and i have a 93 ls i plan on swapping in..my question is i have the obd1 harness from the teg and the obd0 one from the si..could i make my own harness? or should i just buy one? im obvsly not a hack or stupid i dnt want my car screwed up i have heat shrink wrap and the sqweeze connecters..is it possible if so can someone let me knoe how? thanks
Re: obd0-obd1 engine harness? (stealthmodeSI)
to convert the engine harness to run the 93 OBD1 engine, you just need to change distributor connectors (you can purchase a distributor jumper from Rywire) and install a different connector for the cooling fan switch - you will need the OBD0 to OBD1 ECU jumper harness to connect the OBD1 ECU to your chassis harness - you will need to unplug the connector from the MAP sensor on the firewall and plug it into the MAP sensor on the throttle body
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealthmodeSI »</TD></TR><TR><TD CLASS="quote">thats exactly was i thinking..but i should splice in the obd1 injecters right? </TD></TR></TABLE>you can run the OBD0 injectors from the Si with the injector resistor box currently in the car or you can run the OBD1 injectors from the 93 and remove the injector resistor box - you don't need to do any other wiring
all u really need to do is wire the dist. and add a 4 wire o2. then get a ecu jumper harness... pretty simple if u know what ur doing. i have ecu jumprs for 60$ shipped. lmk
I've seen the shitty wiring jobs that EFjones puts out... buy yourself a rywire conversion harness bypass that shitty jumper dude sells for $60.
haters....i dont make the jumpers i just sell them....brand new
op..if u wana save some money just do it ur self. rywire doesnt do conversions anymore. they sell new harnesses for like $375. why spend that much when u can get it fractions cheaper
Here is the link....
http://www.rywire.com/catalog/index....6dd4105e0079cd
i currently have an obd1 b16a in my 90 dx hatch. used the dx harness, did the mpfi conversion, swapped the obd1 plugs onto the harness for the fan switch, obd1 injectors, 4 wire 02 sensor and dizzy. bought a rywire ecu jumper harness. DONE. not hard. i hate seeing ppl being broke *** cheapos and do the ecu wiring themselves..the damn car never starts and it ends up on craigslist! lmao hack jobs like a ****!
bobbyisking
07-07-2008 09:22 AM
