What kind of mudflaps are these??? CRX?
So...I'm a little confused. I went to N1 Concepts, who only sell JDM parts. I picked up a set of rear mudflaps and I was told they are off an EF9. However, when I went to put them on my 91 Si...this happened:
In that pic, two of the screws were in and it was flush with the body on the sides and on the bottom. But obviously it's sticking up over the moldings on the side, and I know full well it should look like this:
So, did I buy CRX flaps? Is the JDM rear bumper slightly different than the 90-91 US bumper? Does anyone want to buy my rear flaps?
Re: What kind of mudflaps are these??? CRX? (hushypushy)
they might be off of a 4DR. they do look awfully close to the original ones tho. i would take em back if your close to them and get the right ones n get what you paid for.
Re: What kind of mudflaps are these??? CRX? (kojack_0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kojack_0 »</TD></TR><TR><TD CLASS="quote">they have to be slightly slanted diagonally.
untill they dont touch the molding.</TD></TR></TABLE>
We tried aligning it in every conceivable way. The way it's pictured is how it actually screws in to the fender. Trying to fix it so the top is aligned correctly produces two problems: 1. the bottom hangs down and it's not flush and 2. (bigger problem) the bolt holes won't line up.
My logic is this: flaps are a direct bolt-on mod. The screw holes are already there and the location of the flaps is not debatable--it only goes on one way. Therefore, if I'm bolting it on and it doesn't fit, the flaps are incorrect.
At this point I'm not sure if I should simply return them...I'm hoping to see someone who can positively ID them so I can perhaps sell them to someone else who needs/wants rear flaps!
btw: Does anyone know if USDM CRX rear flaps will fit a USDM hatch?
they will not fit
the crx mudflaps are longer then the hatch mudlfaps, the rear at least, im not sure if the front mudflaps will fit
Re: What kind of mudflaps are these??? CRX? (wakaranai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wakaranai »</TD></TR><TR><TD CLASS="quote">Those are CRX sedan flaps. </TD></TR></TABLE>
foh doh crx
foh doh crx
Re: (whoa its len 2)
Originally Posted by whoa its len 2
you have sedan mudflaps. same mounting hole pattern but longer up top.
I'll go back to N1 with my car and see if I can swap these out for some hatch ones...they had a set four for EF9 but I didn't pick them up because the back was a little bent from the rear lip
Originally Posted by Pagley
they will not fit
