Help, rear brake conversion for 1989 civic ef
i was wondering if i have to replace the whole rear suspension or just the disc and caliper. and if i have to change the master cylinder.
https://honda-tech.com/forums/showthread.php?t=1508680
Check the FAQ at the top of the EF forum. Scroll down to the 'brakes and suspension' section.
You’ll need trailing arms, calipers, rotors, and parking brake cables for a simple rear disc brake conversion. You don't need to change the master cylinder, but you will want to replace your proportioning valve with a 2040 CRX Si valve.
pnapolitano29
11-26-2014 08:58 PM
asianman139608
10-26-2009 07:21 AM
Ek9andyroo
09-09-2009 12:42 AM
