crx fuel problem.
crx fuel problem.
hey i have a problem with my crx. It has a B&M fuel pressure regulator and the needle is at 0. I was wondering if there is a fuel pump relay and im going to check and see if it is gettin power tonight after i get off work. but i just wanted to check and see if there was a relay before i threw in a new fuel pump. thanks
Re: crx fuel problem.
I'm pretty sure the Fuel relay is mounted above the fuse box where you prp the hood. it's kind of a pain to get to. i've switched mine out twice before i realized the fuel pump was bad.
Projekt CR-X
09-21-2010 06:38 PM
