Turbo'ed D15B7, Major Issues
Old Jan 17, 2010 | 05:28 AM
rocko5845's Avatar
Default Turbo'ed D15B7, Major Issues
I took the ride out on the town the past couple days and came across two major problems. First problem is this: When I accelerate, the car is sluggish, when I give it gas it goes but it hesitates bad. I tried to reach higher rpms to see if it would be any better but its worse.
Problem 2 is this: My spark plugs keeps turning charcoal black. I have tried gapping at 026, 028, 030, 032, and 034 but this keeps occuring. The wires, distributor, cap, and rotor are brand new. I was told that my problem is a fuel issue. I have a FPR that is fully adjustable if that matters in all this. The FPR is set at 38psi.
The car will idle on its own and fire up every time, first try. Even when I rev it up in nuetral I can here it hesitating. It sounds like a spark and fuel problem to me, but I cant figure it out.
Can you please help me out???
Here is my setup:
1992 Honda Civic Dx 1.5L SOHC MT D15B7 Non-Vtec
PO6 Chipped ECU (just have basemap made for my setup for now)
440cc Injectors (Lucas)
Ebay Modified Intake manifold (70% more volume than stock intake)
2.5in Exhaust system
Fully Rebuilt Head
Vitara Turbo Pistons 8:1 compression (not 9:1)
Custom Downpipe
T3/T4 Turbocharger
Compressor Specs :
3" Compressor Inlet
3.000" or 76.20mm Major
1.988" or 50.50mm Minor
Compressor .50 A.R.
Compressor 57 Trim
M24 / T4 Compressor Housing
Turbine Specs :
T3 Type Turbine
11 Blade Type
Turbine .64 A.R.
Turbine 76 Trim
2.560 " or 65.04mm Major
2.204 " or 56.00mm Minor
Manual Turbo Boost controller
38mm External Turbo Wastegate (custom dump pipe)
Turbo Sequential Blow Off Valve (It Can Hold Up To 1200HP Or 25 PSI Of Boost Pressure)
28"x7"x2.5" Front Mount Intercooler/2.5in piping
Adjustable FPR 0-140psi (going to run 38psi to start)
Stock Fuel pump (31-38psi with regulator vacuum attached and 40-47psi without regulator vacuum
Braided Oil Feed & Return Lines
Oil Catch Can
90amp Alternator
10.2mm spark plug wires
NGKBKR7E-11 Plugs (2steps colder) gapped-.026
Adjustable cam gear (set at stock)
58mm throttle body (stock)
Yellow top battery
All sensors are in OEM and working condition and have not been modified in any way.
Old Jan 17, 2010 | 05:42 AM
boostedEF91's Avatar
Default Re: Turbo'ed D15B7, Major Issues
Check your plug wires
Old Jan 17, 2010 | 05:46 AM
rocko5845's Avatar
they are brand new but how can I test them to be sure?
Thanks
Old Jan 17, 2010 | 05:59 AM
rocko5845's Avatar
Is it possible that my 10.2mm wires are just too much, or would that not matter?
Old Jan 17, 2010 | 06:31 AM
cbustuner's Avatar
Do you have a wideband 02 meter or any clue at all as to what you are running air fuel ratio wise?
Old Jan 17, 2010 | 07:44 AM
rocko5845's Avatar
I have no idea actually
Old Jan 17, 2010 | 08:16 AM
Turbo B18C EJ6's Avatar
your also on a basemap so i would'nt expect much from it. you need to get it tuned, basemaps are only so you can drive your car to a tuner.
Old Jan 17, 2010 | 08:42 AM
rocko5845's Avatar
thank you for the response
Old Jan 17, 2010 | 08:47 AM
per4mance's Avatar
tunning is the answer to all problems like this.
Old Jan 17, 2010 | 08:53 AM
sanman000719's Avatar
yup a tuner could strap it down and narow it down without the guessing game man
Old Jan 17, 2010 | 08:56 AM
rocko5845's Avatar
I hope so. I cant afford for this car not to run properly. Everything has been triple checked and I have everyhting working properly. The only thing I lack is the 255lph fuel pump and I'll have that in a few days.
Old Jan 17, 2010 | 09:03 AM
rocko5845's Avatar
Could this be the reason why I have a ticking noise (not knocking)? It sounds like the noise in coming from the injector side but I have looked for leaks many times and haven't found anything.
Old Jan 17, 2010 | 09:08 AM
Crazy_SI_T's Avatar
Thanks
to test wires what you can do i 1. start the car, pop the hood. 2. while its running take one of the spark plug wires out and stick it on a bolt, if you hear it arcing than its a good wire.
Old Jan 17, 2010 | 09:12 AM
rocko5845's Avatar
I did pull the wires one by one while it was runing to see if it made a difference. Every time I pulled one, I got the same thing. It would nearly die. But I'll try the arching test. Thanks.
Old Jan 17, 2010 | 12:57 PM
raiden571's Avatar
most aftermarket injectors are going to be a little louder than oem
Old Jan 17, 2010 | 01:49 PM
Psychoteen101's Avatar
Tune the car, basemap is not helping your cause. Its very possible the tune is off and all it needs to be fixed is to change a few things in the engine management. That is the first place you should look.
Old Jan 17, 2010 | 03:07 PM
rocko5845's Avatar
Thanks for the input. Im going to put the 255lph fuel pump and the stage 3 clutch in and go have a tune very soon. I just hope the basemap will get me to the tuner which is almost 200 miles away.
Old Jan 17, 2010 | 03:08 PM
rocko5845's Avatar
Does anyone have any input about putting the OEM ECU back in the car to get it to a tuner?
Old Jan 17, 2010 | 03:46 PM
CoreyR's Avatar
youll need to put the oem injectors back in the car to run it on the stock ecu. as for your other problem, the car is probably running super rich due to the basemap causing the black plugs and sluggishness.
Old Jan 17, 2010 | 03:57 PM
rocko5845's Avatar
Thanks a lot man. What would happen if I ran the stock ECU with the 440cc injectors in there? Just curious, Im not going to do it if its going to damage anything.
Old Jan 17, 2010 | 06:02 PM
CoreyR's Avatar
it will foul out the plugs due to dumping too much fuel because the ecu thinks its only got 240cc injectors. it wont run for long before the plugs are too fouled to work. if the car runs ok just cruising around on the basemap then just leave it in and stay out of boost till you get to the tuner.
Old Jan 17, 2010 | 06:05 PM
rocko5845's Avatar
ok thanks
Old Jan 17, 2010 | 06:45 PM
boostatic's Avatar
u said it urself in ur post..the plugs keep getting charcoal black..its obvious its running too rich..when u give it gas it dumps fuel in and the spark cant ignite all the fuel..thats y u have the misfiring..its sluggish because it begins to misfire..no ignition no power
Old Jan 17, 2010 | 07:38 PM
rocko5845's Avatar
what is causing so much fuel to dump in? how can I decrease it so that its not running so damn rich?
Old Jan 17, 2010 | 07:40 PM
rocko5845's Avatar
I DONT UNDERSTAND HOW ITS GETTING TOO MUCH FUEL? i FIGURED IT WOULDNT BE GETTING ENOUGH SINCE i DONT HAVE THE 255LPH PUMP IN YET.
