Help Picking out good turbo cams.
Ok im planning on turbo my gsr build that im putting together, well anywho i need help finding good, cheap, reliable camshafts.. Im having problems figuring out the lift/duration and what to look for, I plan on using 91 pump gas and I want around 350-400 hp. I have a port and polished gsr head with crower valves springs and retainers so I could just about use any cams. And i plan on using flat supertech valves, so if anyone has any good info or input please do help
Thanks in advance.!!!
Re: Help Picking out good turbo cams.
hmmm... but i have a intake crower cam and a ctr exhaust cam sould i just stick with them?... and 380 sounds good to me
And really need some info on how to compare cams and understand what the specs mean..
i was on a crower stroker kit in my b18c1 (first build) at 16psi it did 386/302 if I remember right the tq might be off but sounds right to me with the gsr cams
Soo toss out my cams?... Or should I keep and I have a question about exhaust, what size should I go with 2 1/2 or 3?.. And as far as using oem ctr or Itr cams would I have to get an up graded valve springs?..
Well I also got a good deal on a skunk2 mega power exhaust and the piping is 2 3/4... What y'all think about that?.
NO TURBO NEEDS TO BREATH, AND THE BIGGER THE BETTER WICH ALSO LEADS ME TO BELEIVE EFFICENCY OF THE TURBO WILL IMPROVE AS WELL WITH A BIGGER BETTER FLOWING EXHAUST i HAD MY EXHAUST BUILT 3" NO MUFFLER AND ITS FAIRLY QUIET
I made 585whp/385tq 21-23psi with GSR Cams..... ITR Cams will give you a 35-50whp boost over GSR's though or you can just make the same power with less boost.
Use a good straight through 3" Exhaust.
i sue caps to **** off the ones thinking it all about yelling and not just a style of typing, but really im to lazy to take it off what ever its on higher or lower case i could care less
official honda whore
for your power goals any oem cam would work and that skunk2 exhaust would work also (ive seen 450+ on 2.5")
SiR-iNTEGRa
03-02-2012 01:20 PM
