Oil return problem
Old Jan 30, 2010 | 07:15 AM
chris3385's Avatar
Default Oil return problem
First off I am going to say I searched for this problem, never really came up with anything but I am on 56k so it takes awhile to find anything. I am installing my turbo kit on my 92 EG with a b18c swap. I have a SLS shorty manifold and a GT3255b turbo. The oil pan I have already had a -10an fitting welded to it. I went to make my oil return line I got from fast-turbo and once I screw in the 45 degree fitting in the turbo, the fitting on the turbo is about 3 inches from the fitting in the oil pan and lines up perfectly and give me no room to run my an fittings and line. I found a piece of thick rubber hose, the inside diameter is 3/4 of a inch, big enough to fit over the an fittings and clamped. What I am wondering is if this would be fine? Will the rubber hose hold up to the heat? Does it matter that I would be running a bigger return line than usual?
Thanks,
Chris
Old Jan 30, 2010 | 05:10 PM
Dual Cam Killer's Avatar
Default Re: Oil return problem
you should be fine man. The return line has no pressure behind it, only gravity moves the oil from the turbo to the oil pan. As long as the hose clamps are as snug as you can get em without stripping em, u should be ok. Now if you wanna be 1000% safe and sure, go with a steel braided line and fittings. U said the ends are very close, all you have to do to get at least an inch of length is clock ur turbo. Loosen the bolts on the cool side and hot side and rotate the inner housing to your liking and tighten it all back up. should be a snap.
Old Jan 30, 2010 | 07:41 PM
boostedcivicsir's Avatar
Mr. Badwrench
you can clock the center a little off horizontal. just a little.
i would use braided clamped over regular hose. it can handle the heat, but heat and oil, it will swell and leak.
Old Jan 30, 2010 | 08:51 PM
Yea, Hes correct.
Old Jan 30, 2010 | 09:12 PM
kyden's Avatar
i would find some line that's rated for heat and oil.
MalcolmV8
Dec 5, 2011 05:29 PM
95lscivic
Feb 24, 2010 06:41 PM
Type-ARR
Nov 8, 2007 04:22 AM
alfee
Jun 28, 2004 04:10 PM
torr
Apr 14, 2004 07:48 AM
