No boost?? Help?
Old Jan 17, 2010 | 03:53 PM
kerleyboy's Avatar
Default No boost?? Help?
fixed.
Old Jan 17, 2010 | 03:56 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: No boost?? Help?
more info on setup. ems? define spitting and sputtering.
Old Jan 17, 2010 | 04:35 PM
cjordan's Avatar
intercooler piping not tightened properly?
Old Jan 17, 2010 | 04:39 PM
kerleyboy's Avatar
pretty sure ive got it all on tight, but i'll double check.
but would i still be getting some boost..
Old Jan 17, 2010 | 04:46 PM
Mr. Badwrench
not if your ems isnt allowing it. what are you doing to suppliment all that extra air?
Old Jan 17, 2010 | 05:36 PM
zedron's Avatar
I once had an issue with no boost. After checking all lines, charge piping, BOV, WG. It was actually the turbo was seized from a piece of metal that got wedged inside because I didn't know my manifold had cracked and that piece fell into the housing.
Old Jan 19, 2010 | 12:06 PM
krc91987's Avatar
I had a dsm with the same problem, no one had an answer, including a 30yr mitsu master tech who specialized in dsm's, ended up being that the injectors were pinned open and would flood the engine, thus messing everything else up, not saying thats your problem but might be worth a look
Old Jan 19, 2010 | 12:11 PM
jhammond_82's Avatar
Reject Papi
yeah, if all you did was install a turbo, and injectors, your ecu won't let you make boost. its gonna flood the engine. do you have a basemap chipped in your ecu?
Hondacivic1995
Apr 17, 2011 04:40 PM
T9U4ReBgO
Mar 6, 2008 09:11 AM
90AcuraIntegra04
Feb 4, 2006 11:25 AM
96turboteg18
Oct 20, 2004 12:02 PM
snake01
Jul 28, 2002 09:50 PM
