Camshalf for turbo GS-R...
Hi im looking to get some cams for my turbo gsr and i wondering if you guys have some idea for which cams are good for turbo. ( skunk2, bisi, BC, type r, ect...) anything helps. thanks.
Re: Camshalf for turbo GS-R...
Yes. we need a little more info about what your running. size of motor. goals you want. etc. If your just running just a stock gsr motor. with a turbo on around 10psi. typeR cams would be a really good choice. Most other aftermarket cams require valvetrain. so you'll need to look into upgrading that.
Block:18c1 golden eagle sleeve 84mm bore, JE 9:1 comp, eagle rods, gsr crank with micro polish balance. Head:gsr p&p, BC dual springs and Ti retainers, supertech valve guides, i dont have valves yet but might get supertech .5mm dish valves, i dont know yet. i dont know what turbo set im gonna use but im aiming +500whp. penny for your thoughts.lol.
Stock GSR cams will make 500whp no problem. If you really want get cams then go for ITR or CTR cams. Skunk tuner 1's would be a good upgrade if you want to make more power down the road.
itr cams are the best overall..but it depends more on your turbo setup what cams to use..topmount will benefit from bigger cams like the skunk2 pro 1s, or the ipg v1 and the crower stage 3 i heard make good power...a log,ramhorn,mini will be better with gsr cams or itr/skunk2 tuner 1s...
I was planing on using ramhorn but i dont know the turbo size yet, maybe 57 trim. i dont know, what do you guys think? have you guys hear anything about BC stg2 turbo cams at all? Thanks for replay.
