catch can problem
Old Jan 16, 2010 | 08:52 PM
eg:R's Avatar
Default catch can problem
what can be the problem if my catch can is overfill and spilling during runs. it was never like this before.
Old Jan 17, 2010 | 10:33 PM
eg:R's Avatar
Default Re: catch can problem
anyone
Old Jan 17, 2010 | 10:35 PM
GT35R_EF's Avatar
Make mine whatever you want
excessive blow-by past the rings. How big is the catch can?
Old Jan 17, 2010 | 11:07 PM
zedron's Avatar
Have you ever emptied it? They do need to be emptied over time if you dont have it setup to drain back into motor.
Old Jan 18, 2010 | 09:04 AM
welfarepc's Avatar
ring lands, are yours still in one piece?
Old Jan 18, 2010 | 09:05 AM
YARO.'s Avatar
If it was never doing it before than look into your motors health, comp test and leak down. Maybe the catch can is just too small?
Old Jan 18, 2010 | 02:37 PM
Robert Padron's Avatar
Or maybe your pcv system isn't well suited for your setup.
Old Jan 18, 2010 | 04:51 PM
eg:R's Avatar
the catch can is about 1qt. and i have it drain back to the block. compression test result were 165-175 across. Pistons are arias 9:1. no leakdown test yet. i also have the valve cover breather plug to the catchcan too if that matters.
Old Jan 24, 2010 | 01:24 AM
eg:R's Avatar
ok, i put a bigger catch can on and it doesnt seem to be spilling anymore. this new one may be up to 2qts. so its about twice the side of my other one. but the thing is that my other smaller one never over fill before until now. so There still got to be a problem right??
Old Jan 24, 2010 | 05:53 PM
boostedcivicsir's Avatar
Mr. Badwrench
what is the setup? also i have seen that once the filters are wet, they spew all the time.
i had an issue where i lifted the head, and was pushing coolant. and with that i think passed some oil.
fixed the hg, cleaned the filters, and made 4 more passes no issues.
we need to see your complete setup.
Old Jan 25, 2010 | 08:56 AM
keving85's Avatar
I agree. If it's the ring lands the compression test can fool ya. Leak down test will show in yellow.....
Old Jan 25, 2010 | 12:18 PM
Mr. Badwrench
an improper setup catch can will overflow, im not saying that the ringlands may or may not be the issue, but it is kinda hard to make calls like this without knowing all the facts.
killudie123
Nov 6, 2011 12:13 PM
sinister357
Aug 25, 2007 10:05 PM
Ruben19
Oct 2, 2006 08:01 PM
crxvtecturbo
Apr 18, 2005 08:51 AM
greenb20
Mar 4, 2005 08:35 AM
