Boosting 96 integra (need help with ecu)
Old Feb 1, 2010 | 10:04 AM
Arthas's Avatar
Default Boosting 96 integra (need help with ecu)
Hello all, im boosting my 96 integra , and its a full LS motor with a gsr tranny , but I was woundering if I had to use the P28 to tune the car, or can i also use the Po6 ecu , iv been hearing that some people do use the po6, because its just like the p28 but with out the vtec, but just needed a forsure answer, before i go an buy a p28, the car is going to be boosting around 8 psi
Thanks
-arthas
Old Feb 1, 2010 | 10:20 AM
kyden's Avatar
Default Re: Boosting 96 integra (need help with ecu)
any of them will work. p75, pr4 will also work.
Old Feb 2, 2010 | 12:11 PM
Arthas's Avatar
Are P75 and PR4 VTEC? and what cars are they from?
Old Feb 2, 2010 | 01:57 PM
lsvtecracer's Avatar
The obd1 pr4 ecu is from the 92-93 integra and the obd1 p75 is from the 94-95 integra. You can use the p06 ecu if you want since you don't have vtec. What ems do you plan to use?? Either way, the obd1 po6 with obd2-obd1 conversion will work fine for your application.
Steve
Old Feb 2, 2010 | 02:09 PM
mtber's Avatar
You will need an obd2a to obd1 ecu jumper & a chipped obd1 non-vtec ecu.
You should probably consider getting a pre-chipped/socketed ecu.
Check out http://www.phearable.net/tech/efibeginnerguide.html for more information on this subject.
Old Feb 2, 2010 | 10:46 PM
Arthas's Avatar
Steve
Oh okay cool. That way I can save some money from not getting the P28.
So the ECU I need to find is P06, PR4, and P75? Ill keep an eye out, I appreciate it.
As for the EMS I have no idea. Ill have to speak with the tuner but hes in Westminster, CA
How will a pre chipped ECU help me vs. getting a virgin? Will I need to buy a chip set or something?
I bought the P28 for my EF from JDM James and it came pre chipped with a base map.
Old Feb 2, 2010 | 11:25 PM
TehGhett0P1mp's Avatar
Are you planning on chipping it? if not you need a chipped ecu and something to tune with as well...I would suggest looking at the FAQ it explains a lot of this stuff already.
Even if the ecu does not come with vtec components usually you can add them onces its chipped depending on which ecu you get.
What are you going to tune on? I am assuming chrome since ur looking for a chipped ecu?
Old Feb 4, 2010 | 05:36 PM
Arthas's Avatar
Sorry im new to this whole chipping set up.
I was reading and I guess ill have to chip it. I was looking at a few chipping kits on eGay and it seems like I can get the kit for about $40.
So basically I just chip it, then take it to my tuner for a tune? How is he going to tune it though?
TurbodTegra
Mar 10, 2011 12:46 PM
SidewayzCivic
Apr 27, 2010 04:48 PM
boosted96lsteg
Engine Management and Tuning
May 13, 2008 02:30 PM
hondateg10
Mar 25, 2007 03:50 PM
cyrock
Jun 25, 2006 01:29 AM
