compression #'s for built engines?
Old Jan 22, 2010 | 09:16 AM
jchrm80's Avatar
Default compression #'s for built engines?
I have an 81.5 gsr block with b16 head. Cp 9.0:1 pistons. Just wondering if there was a spec for what compression numbers should be or if you all could give me an average? Just checked mine and they are all about 140, but i have nothing to compare that to. Those numbers are with no oil added and the engine was about 30*f haha.
Old Jan 22, 2010 | 09:30 AM
HiProfile's Avatar
Default Re: compression #'s for built engines?
If they are all w/in 5% of each other (137-143psi), then they are all okay. You have a better chance at winning your local "pick 4" lottery than getting 4 cylinders dying with the exact same psi readings. The important thing is consistency. Make sure you treated each cylinder the same - WOT while cranking same number of times. I usually let it pump the gauge 3 times with all 4 plugs out & WOT.
If you're looking to get the actual compression ratio, you'll have to do it another way. The error involved with an assembled motor will be terrible, so tearing it down & "CCing" the combustion chaimbers and tdc cylinders is about the only accurate way.
Old Jan 22, 2010 | 01:49 PM
Mikey3000's Avatar
your motor should also be warm so the "sealing surfaces" are at their operating temp sizes, e.g. rings, valves, etc.
Old Jan 22, 2010 | 02:53 PM
jchrm80's Avatar
yeah i knew that much but I was just trying to get an estimate to make sure they were all about even. I'll do a hot compression check and compare the numbers. thanks for the input.
Old Jan 22, 2010 | 06:00 PM
Spoolin18's Avatar
As long as they are all within 5% of each other it is fine. I run a 84.5mm GSR with the same compression ratio and all of mine are around 140psi as well.
doublezerohatch
Jul 1, 2013 08:03 AM
jorge59la
Mar 16, 2007 10:34 PM
EARLdaSQUIRREL
Nov 25, 2006 07:05 PM
builtprelude
Jan 22, 2004 10:49 PM
