AR Performance Turbo ITR 630whp@26psi E85
A quick video clip of the 1st baseline dyno pull on the wastegate springs after setting up the timing. The car was built by Casper from AR Performance and tuned by Lance HoLung. I did not get to stay and video the final pulls. The car ended up making 630whp@26psi on E85.
B18C block
84mm
B18C5 head
pro 2 cams
valve springs & retainers
Edelebrock IM
Turbo setup
BW 372 turbo
top mount mani
dual 44 tial wg's
1600cc inj
50mm tial BOV
3 inch charge piping
bar and plate intercooler
AEM
http://www.youtube.com/watch?v=GvW0apRvcDI
B18C block
84mm
B18C5 head
pro 2 cams
Edelebrock IM
Turbo setup
BW 372 turbo
top mount mani
dual 44 tial wg's
1600cc inj
50mm tial BOV
AEM
Re: AR Performance Turbo ITR 630whp@26psi E85
the idle was set at 1100 rpm I think. It sounds like a stock car at idle. I really didn't think about that until you guys mentioned it. I know the customer was very happy with the outcome.
the car idles at 1000 rpm and fuel set up is aeromotive pump -10 in -8 return we will come back to the dyno when the customer is ready thank you scott for the vid
any work done to ports on itr head? or just a valve job..and why such a big turbo for 630whp did it run out of fuel? and why pro2s not pro1 i though the pro1s were better for boost..
-The owner of the car has never driven a vehicle with this much power so he is going to get use to the car then retune when he's ready for more.
-Pro 2's where used because that's what he had. Pro 1's are more than enough for any high hp setups but we just worked with what we had.
looks good Casper. With a set of pro1's it will probably make close to 700hp on the same boost. I tried the pro2 on the orange car and went from 870hp to 820hp
gotta love E85!!
gotta love E85!!
I know they did a street run after the dyno. I do not know if anyone has video footage (if they do I'll post it). I hear the car's boost control/traction setup is awesome and that it barely has any wheel spin.
J.nguyen
05-29-2006 12:32 PM
