hondata and non functional temp gauge
Old Jan 15, 2010 | 05:17 PM
cantaffordaccord's Avatar
Default hondata and non functional temp gauge
I really want to use hondata s300 on my turbo 01 f23 accord however I have a question or two before I can decide.
first off when I look at notes in the hondata page going by application I find this information below VVVVV I am wondering if this will affect my cars driveability or tuneability.
2000-2002 Accords will no longer have a functional temp gauge.
Using a Hondata system on a 2000-2002 Accord as done at the user's discretion is not supported by Hondata
second question would be. Is it better to re wire my three wire iacv or swap a 2 wire iacv in?
Old Jan 15, 2010 | 05:56 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: hondata and non functional temp gauge
looked real quickly at your other post. having the gauge not work is no big deal. you can get another gauge to do the dirty work.
as far as 3 to 2 wire, the po6 only uses a 2 wire, and all the y7 swaps i have done have gone to a 2 wire setup with no issues.
although i have never use a d/b ecm to run an f/h i know it is possible.
hope that helps.
Old Jan 15, 2010 | 09:02 PM
I was under the impression that the p06 was for the f22 non vtec accord I was wrong .
I guess I will get a p28 and have the installer disable vtec on the ecu unless there is a bettrer ecu?
Old Jan 16, 2010 | 04:48 AM
Mr. Badwrench
everything is the same from the p06 to the p28 except the vtec controlling. funny hting is you can install the vtec components into the p06. OR hondata has a map switching feature now that uses one of the outputs to run the solenoid. so you dont need to install the parts.
Old Jan 16, 2010 | 01:10 PM
so from what I have gatherd from here and other places LOL. my f23 should preform like any other honda running hondata?
Old Jan 17, 2010 | 11:11 AM
Mr. Badwrench
it should, remember i havent used it on an f/h but know it has been done.
2001GSRSC
Jan 30, 2018 12:10 PM
91b18a1ls
Engine Management and Tuning
Mar 19, 2015 03:44 PM
bigtom388
Jul 28, 2011 09:45 AM
