ACL Race Bearings
Old Jan 25, 2010 | 04:49 PM
crashsvg's Avatar
Default ACL Race Bearings
any one got any feed back about ACL Race Bearings? do they hold up better than normal bearings..
or could some one direct me to some better ones
Old Jan 25, 2010 | 06:23 PM
redflaredcrx90's Avatar
Default Re: ACL Race Bearings
i run acl brearing in both my cars. if im right they have an extra layer of coating for break ins.
Old Jan 25, 2010 | 09:04 PM
civic_r87111's Avatar
To tell u the truth there is a lot of research that goes into bearing and the coating but most high performance bearing r all the same. If u want to do some reading on it check this out: http://mahleclevite.com/pubs_guides.asp
And http://mahleclevite.com/pubs_detail.asp?c=1&id=108
Old Jan 25, 2010 | 09:58 PM
hondapowerb16a2's Avatar
That's all I ever buy built four motors now with them and never had a bearing fail
Old Jan 26, 2010 | 02:55 AM
crashsvg's Avatar
thanks guy..
Old Jan 26, 2010 | 06:37 AM
d112crzy's Avatar
All ACL "race" bearings are are bearings with an extra .001" of clearance.
Old Jan 26, 2010 | 02:16 PM
Nichelson_Performance's Avatar
i always thought they didn't have as many layers are regular bearings
i'm currently running acl race bearings in my d16 vitara build and have not had one bit of problem with them.
i also have ran the regular acl's, they are very good also
Old Jan 26, 2010 | 09:12 PM
JFK78's Avatar
There are quite a few differences between ACL race and normal ACL Duraglides.
They are standard oil clearance, but can be ordered with the additional .001" of oil clearance if desired.
All the needed info is here:
http://www.aclperformance.com.au/us/...bearingsus.htm
Old Jan 6, 2014 | 04:32 PM
turbozcteg's Avatar
Dont you have to have the crank machined because the differences in sizes per journal ?
Old Jan 6, 2014 | 06:36 PM
Muckman's Avatar
Moderator in Chief
You can polish off a few ten thou off the crank journals but that is all unless you want to risk removing the nitrided treatment. If you need difference sizes you go with OEM bearings that come in different sizes (colors).
Old Jan 9, 2014 | 05:09 AM
motoxxxman's Avatar
not true. they are available in std size and extra 0.001" clearance size. the extra clearance bearings are denoted with an "X" in the part number. the ones without an "X" are normal clearance sizes.
I run acl race bearings in all my motors and customer motors as well and have never had one fail either. I have had failures with bearings of other brands though
Old Jan 9, 2014 | 05:30 AM
SPOOLINmatt's Avatar
I run Clevite H and HX
boostontheD
Jan 16, 2012 10:42 PM
401B18TEG
Oct 4, 2007 04:23 AM
adubaz7
Oct 3, 2007 07:49 PM
IN VTEC
Mar 18, 2006 08:40 PM
