differences between z6 crank and y8 crank
Old Feb 3, 2010 | 06:42 AM
AbitAvenger's Avatar
Default differences between z6 crank and y8 crank
Are there any? I've been looking for a crank for my new build (d15b7, z6 head, vitatas and FJ rods) and I keep finding all of these y8 cranks and no z6 cranks. Can I run a y8 crank in a d15b7?
Old Feb 3, 2010 | 06:46 AM
speedooo's Avatar
Default Re: differences between z6 crank and y8 crank
idk if you can put the 1.6 crank in a 1.5...deck heights are probably different.
anyway, the oiling systems between the two are different, y8 is more prone to eating bearings
Old Feb 3, 2010 | 07:02 AM
shifty35's Avatar
Z6 has two oiling holes per bearing (at least on the rods) compared to one on the Y7/Y8.
No, you can't use 1.6L cranks in the 1.5L block - the mains aren't the same diameter.
so I cant make my 1.5 a 1.6 by putting a 1.6 crank in
Old Feb 3, 2010 | 07:09 AM
HiProfile's Avatar
I noticed that after a clunker I bought blew up a y7. They can be fixed at most shops, as crossdrilling cranks isnt unusual for some v8's. It won't hurt to chamfer & micropolish it either.
The main y7/y8 problem is the oil pump. I've seen a few people put a z6 pump/pan on a y8 and drive it like they stole it w/o issues (besides cops).
Old Feb 3, 2010 | 07:16 AM
I guess I'll be looking for a d16 block w/ crank or a d15 crank then.
Wish I could get pics of the bearings in the d15 I pulled apart. You guys wouldn't blame me for wanting another crank lol
Old Feb 3, 2010 | 07:47 AM
HiProfile's Avatar
I can relate. That block I mentioned had 2 spun rods, a 3rd rod siezed/snapped, and 2 spun mains with a 3rd was nearly gone. i didn't have shavings, I had flattened dimes all over...
In many cases local people will think the d16 has zero potential, meaning zero worth. I got a full swap for $250 a while back, still have it too. The best part is any sohc d15/d16 head will bolt onto it, assuming you use the right parts.
Old Feb 22, 2012 | 10:25 AM
fox_the_shadow's Avatar
What about useing a y8 crank in z6 block is there much dif or they pretty much the same
Old Feb 22, 2012 | 12:35 PM
Hybrid96EK's Avatar
The Y8 crank is inferior. If you can, get the Z6 or even an A6 crank. Its a much better choice due to the difference in the oil galleries as mentioned before. Y series block are well known for spinning rod bearings... and please don't start a debate about the oil pumps being the cause. This isn't the case.
Dmonster
May 28, 2010 10:36 PM
TylerB
Mar 28, 2009 05:52 AM
stiffdogg06
Jul 9, 2008 09:00 PM
b20accord
Aug 18, 2007 06:44 PM
HiProfile
Oct 10, 2006 06:19 PM
