550+ hp engine mounts?
Old Jan 20, 2010 | 06:01 AM
highroller54's Avatar
Default 550+ hp engine mounts?
Whats everyone running for big power b series in a eg? I see alot of guys with just hasport and such but I cant get my head around going from five mounts to three and running some decent power. Is anyone still running the two front mounts or are they just plain not needed?
Old Jan 20, 2010 | 07:27 AM
Glove's Avatar
Default Re: 550+ hp engine mounts?
bump for the answer,
why dont innovate and hasport make all 5 mounts?
Old Jan 20, 2010 | 08:38 AM
98exn20's Avatar
Get the solid avid motor mounts.
Old Jan 20, 2010 | 09:19 AM
boostedEF91's Avatar
3 motor mounts is plenty enough. no need for the front torque mounts. using solid mounts. or even hasport 88A mounts are plenty enough.
Old Jan 20, 2010 | 11:49 AM
Turbo-LS's Avatar
Thre mounts is plenty, if you want to run the front lower torque mounts just get inserts with stock mounts. I personally run all stock mounts with inserts in all five of them and my motor is rock solid and doesnt vibrate like a heavier duty mount will do
Old Jan 20, 2010 | 01:04 PM
90blackcrx's Avatar
Hasport or innovative, both good companies, hasport's are easier to come by. I wouldn't recommend the solid mounts, unless the car was gonna be just a drag car, and you were going with something like a long shifter setup from t1.
Old Jan 20, 2010 | 01:27 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
me too. I have the innovative 85a's i think that's what they are called.
the GForce shifter requires solid mounts only.
you dont need all 5 mounts with the race mounts
Old Jan 20, 2010 | 02:02 PM
I.C.C.'s Avatar
I used the Hasport 88A "extreme race" mounts with high 500's whp and they were great... Engine was rock solid... Zero movement at all... I am using them again on my new setup that should make close to 800whp... I will eventually switch to solid mounts when I get the T1 shift kit and MFactory Pro Syncro gear set....
2kdrift
Aug 9, 2014 08:00 PM
B_Swapped93
Oct 28, 2013 06:22 AM
murphy95si
Jun 8, 2013 04:51 PM
hard_boiled_EG
Dec 10, 2009 08:39 PM
